Possibly silly whee...
[Closed] Possibly silly wheel size question.. Stooge content!
7 Users
Evening all,
Following on from my recent what bike thread I have taken a liking to the Stooge steel hardtail frame.
However, I appear to have missed this whole 27.5+/29B+ tyre size thing.. Can somebody explain what it is before my brain implodes? Am I right in thinking the Stooge can run either a 27.5" wheel or a 29" wheel? Is this new tyre size merely down to the width / over all circumference of the tyre?
Ie.. Ride it on 27.5" wheels with a wide larger circumference tyre and it is technically a 29er that doesn't look daft? Or have I missed the point by a mile?
Also, at a smidge under 5ft 6 would I size up ok on the one size fits most frame?
Apologies for the maybe obvious question and possible daft conclusion! I'm an old fashioned 26er dude!
Posted : 26/11/2015 9:49 pm
The stooge Mk 2 will run both, before you dismiss +tyres as daft try some. The grip and comfort are very good. Cheers 1 shed.
Posted : 26/11/2015 11:40 pm
I didn't dismiss them as daft. I asked what the difference was between them and normal tyres/wheels.
Anybody else?
Posted : 27/11/2015 8:41 am
Stooge was designed to run 29 in the rear and a larger 29+ up front for a bit more cushion and grip. I.e. old skool set up of slinky rear burlier front. Folks have since discovered that you can fit a 27.5 + in the rear and front which effectively gives you the same outside diameter of a 29 (give or take a smudge) but with more volume so you get a bit more grip and comfort. A wtb 2.8 27.5 + is actually about the same width as a 2.4 29erlike a racing ralph.
The new mk 2 frame has a little bit more clearance in the frame so a narrow 29+ like a fat b nimble on a 35mm rim will squeeze in with a fag paper clearance.
There is also a titanium proper 29+ on the way
at 5ft 6 you should be fine as the standover is huge but may need a nice 35-50 mm stem
so in summary, its a massively versatile frame (also goes great with a boingy fork) and what ever wheel size you use it will ride really well.
Posted : 27/11/2015 9:05 am
Thanks Tazzy, I was nearly correct then! It does appear to be very versatile, the ability to run normal width and wide tyres is good.
I'd definitely run it with 27.5" wheels.. I think!
I did suspect I'd have to run a shorter than normal stem as the overall reach on the Stooge is 24mm more than the Cotic, I ran a 50mm on that and the ETT combined with stem length was 627mm. So I would need to run a 30mm to see how that felt.
Posted : 27/11/2015 9:44 am
27.5+ I think you mean, 27.5" tyres might make the BB uncomfortably low (the +tyres tend to be taller)
Posted : 27/11/2015 9:49 am
eh up. Yeah, the Stooge MK2 was redesigned with the idea of being able to run 650B+ up to 3" in the rear. As Tazzy said, the MK1 was designed around 29+/29 front to rear, but after trying out the 27+ wheels n tyres i was blown away by how well it rode, especially in the woods where it became super agile and hoppy poppy (?), so i upped the clearance substantially on the second gen. The size and dimension of the wheels and tyres really suits the frame, i run a 3.2 on the front and a 3 on the back, it rocks along. The 29+/29x2.4 combo works great for big days out on the mountains, but essentially the 27+ takes it to another level when it comes to fun and agility, especially if you like to fling your bike around a fair bit, plus the comfort from the big tyres genuinely does negate the need for suspension for most types of riding.
At 5'6 you'd fit great, as Tazzy said, run a nice short stem and you'll get a great ride. where do you live 1981miked, you're more than welcome to hop over to mine and try a few bikes out if the journey's not too great for you. I always like to help getting a bike set up properly for the rider so if you've got any questions are just fancy having a general chat about the frames and set-up give me a shout at andrewj.stevenson@hotmail.co.uk. cheers, Andy
Posted : 27/11/2015 9:39 pm
Plus, that Andy ^^^ bloke is a right nice chap.
Posted : 27/11/2015 10:19 pm
Thanks for the reply Andy, nice to get the info straight from the guy who would know best. I like to chuck my bikes around a bit so running the smaller wheels is what I had in mind. How do they ride for Sunday saunters on the local cycle loop? Are the wider tyres really draggy? Or is it worth running something a bit narrower?
I appreciate it won't be its natural terrain but as longs as it's fun and not a drag I reckon it will be fine.
I was going to fire an email of in your direction next week anyway, what wheels are people running on the bike? I have always ridden 26" on mountain bikes so this is a whole new experience for me and not sure where I should be looking.
Location wise I'm up in Scotland so nowhere near you or I would definitely be making a trip to see the bike and swing a leg over one. I was down that area a bit with work earlier in the year but working more oop north now.
I reckoned a 30mm stem would be a good start point to try and keep the reach on par with the Cotic which I always found fairly comfy, I would put some stem spacers on to raise the front end a bit as I did suffer with numb hands a fair bit so taking the weight off the wrists would be beneficial. Am I on the right lines? Still undecided on bar choice as yet, nothing too fancy, maybe a riser? Any progress on your motocross bar I saw mention of in a post?
Never ran an EBB either so I'll do some research into that, I assume it runs a standard BB within the EBB?
Apologies for all the questions..
Ps, already decided it's Magenta for the colour..
Posted : 27/11/2015 10:34 pm
The 'Moto' bar samples are landing next week, really looking forward to getting a set on my bike and testing them out, i'll post photos as soon as i have them, but if i love them as much as i'm expecting to then they'll be available for sale in about a month or so. hey'll suit your riding style perfectly.
I've been using my B+ bike solidly all summer. i know i always refer to ragging int he woods, but in reality my rides are just as likely to be a 3 hour spin over the moors above llangollen and i've never wished for a bigger 29er wheel. As you're used to 26 i think you'll be very impressed with the comfort and rollabilty (is that even a word?) of the B+. As for rims, go for a 30-35mm rim or over.I have WTB Scraper rims on one bike, on the other i'm using a set of Rovals which are thinner and much lighter and spin up loads easier. Either way, both are fast and not draggy.
EBB runs a regular 68mm bottom bracket.
re setup, at 5'6 with a riser bar, you'd probably only need 5mm of spacers. Start tall and work your way down, the truth will find you pretty quickly.
cheers, Andy
Posted : 27/11/2015 11:17 pm
All sounds good to me so far, I'll have a look at the recommended wheels, I'm inclined to go for the lighter set up as I'm not heavy on gear as I tend to take the faster and less rocky line.
Any ideas what I can get a set of pre built Rovals?
Good advice on the bars aswell as I was imagining I would need more height up front than 5mm spacer. That's something that will work itself out I'm sure.
Is there anything of note on the BB side? How do I know what position to run it in etc? I'm I'm running 1x10 do I just treat it as a normal BB shell and fit it as normal?
Posted : 28/11/2015 10:10 am
re the BB, just treat it as regular, everything will fit fine. I run an XT 1x10 on one of mine, perfect chainline.
The Roval traverse wheels are £400 RRP, send me an e-mail, i should be able to get hold of a set if you wanted 😉
Posted : 29/11/2015 12:23 am
Will do Andy, I'll email you next week. Have a good Sunday.
Posted : 29/11/2015 1:05 am
What tyres can the MK1 frame run?
Can you run 27+ on the back? Or is it just 29?
I presume the MK1 can run both 29 and 29+ on the front?
For a MK1 fraem what tye and rim combo would you recommend?
oli
Posted : 13/12/2015 5:53 pm
Hi Oli, re your questions:
It was originally designed around a 29x3 on the front, 29x2.3 on the back.
Yes, a 27+ tyre up to 2.8 will fit fine on rims up to 45mm. The MK2 frame has a lot more clearance specifically for the bigger B+ tyres.
The geometry is designed around a larger diameter front tyre, so though a normal 29 front tyre can be used it will affect the geometry slightly, makes it less bulldozery on the downs, for regular trail riding the front becomes a little more reactive.
Either run the 29+/2.3 combo or run B+ with a 3.00 upfront and a 2.8 outback to preserve the geometry. With B+ it feels like a large BMX, very fast and lively, makes you want to ride down things.
Hope that helps, cheers, Andy
Posted : 15/12/2015 9:49 pm
