Possibly a silly fr...
Possibly a silly frame bearing change question
3 Users
2 Reactions
Today's plan is to do the bearings in my Camber back end.
New ones going in, put in dry or just the slightest smidge of grease on the outer surfaces to help slide in/prevent them corroding in?
Thanks
Never done this before wish me luck 😬
Posted : 25/02/2023 8:31 am
 Yak
Not dry. Put a bit of grease on.
But if the bearing seat is loose or worn then use bearing fit compound.
Posted : 25/02/2023 8:35 am
Grease where its going and grease the bearing outer. Better too much than too little, and any squeezed out can be easily wiped away.
Posted : 25/02/2023 1:11 pm
