I'm quite happy with my ghetto fire extinguisher option but wondered if this might be a cheap inflation tool? Perhaps valve core out, skinny adapter in and on goes the pump??
https://www.aldi.co.uk/p/093303031180100
If it might work then £5.99 is a bargain 😀
If not then just berate me!
I think it probably wouldn't work in the same way as a ghetto inflator/coke bottle method. Those work with a sudden quick burst of air whereas this is just a trickle.
Fair enough...
I wouldn't expect it could pump anywhere near 30-40 psi. ??
It was a baby son enforced early morning thought!
I've got something similar - great for air beds, but not enough oomph for normal tyres. 🙂
Annoyingly I bought a new pump for inflating camping beds and paddling pools last week, it cost a couple of quid more than that yet still requires manual labour...
Might buy this item too just to save my precious back a bit...
Cheers OP.
*thread reported for being rubbish*
Haha thanks legend
I know the 12v versions of those are pants but curious if the 240v mains ones are any better (air flow-wise), for general stuff (not inflating tubeless tyres)
I have a Go outdoors version - it's a 240 12v transformer attached to a lead 🙂 Will not work for tubeless.
Got one of those for the kids inflatable pool. It's not strong enough and is easily overwhelmed by back pressure.
I mentioned this on another thread, but something like this - http://www.gelert.com/gelert-double-action-pump-784155 - does the job perfectly.
Valve core out, long adapter fits in the valve perfectly, once good pump and the tyre seats straight away. Done 3 now, all up first time. Once you've used the "big" pump to seat the tyre, a regular track pump does the job just fine after that.
Slightly off at a tangent, but has anyone tried to inflate an air mattress with a track pump ? Totally different valves I believe.
"I know the 12v versions of those are pants"
toptip have the engine running, same volts but a lot more amps.
Because it's double action, that Gelert one will maintain a flow, which is where you struggle with track pumps sometimes as the air leak out on the up stroke faster than you can put it in on the down. That's a good solution Woody2000
The OP's Aldi one is a fan really, not a pump.
