POC Helmet Sizing
POC Helmet Sizing
10 Users
Do these come up a bit big or small? I'm pretty much between M/L and l/XL with about 58.5cm head. M/L is up to 58 and L/XL starts at 59.
Quite annoying really
Posted : 27/02/2023 1:42 pm
Hi there.
Go elsewhere in my opinion. I have a slightly larger head at 60cm and I couldn't get the medium on (DH helmet BTW) without seriously causing myself ear damage!
I now use a large and I look ridiculous, it's enormous! A mate is pretty senior in POC so I get cheap stuff but nothing really fits which is a bit of a bummer!
Whereas a medium GIRO Tyrant and Source fit perfectly and I don't look quite so odd. Medium Giro are sized up to 59cm so go figure.
I guess try before you buy.
Posted : 27/02/2023 2:03 pm
 a11y
I've been through this and concluded I can't wear POC helmets - I'm annoyingly between sizes with a bawhair-under-59cm head. My recent findings in case it helps:
POC: medium too tight, large too loose (on both the Kortals and Axion Races I tried in both sizes).
Giro: same as POC, falling beteen M and L.
Troy Lee: Stage full-facer great fit in XL/XXL 60-63cm (must be small made), but the same sized A3 was too loose.
7iDP: Project 23 FFer too loose in L 59-60cm, but their M1 (same as the old 661 Comp FFer) in L 59-60 is perfect.
I've tried and returned a lot of helmets recently and currently using Lazer helmets - their large size range is slightly smaller than others, starting at 58cm. Both their Chiru and Coyote helmets (MIPS versions) are perfect on my head.
Posted : 27/02/2023 2:14 pm
I measured myself at 58cm and a little bit and a size M Kortal fits me great with a few clicks to go bigger if I’d needed. As always it depends on the shape of your head so you’ll probably just have to try one on.
Posted : 27/02/2023 3:48 pm
when i moved from a Large Giro Montaro i was also on the cusp of sizing. I ordered both M/L and XL in the Tectal Spin Race.
The M/L fits like a glove, the XL was absolutely massive.
Been using the M/L Tectal for ages now, really like it. I have one for commuting and one for MTB. Most likely will replace with the same when the time comes!
Posted : 28/02/2023 8:37 am
I take the same approach with bike helmets that I took for decades with motorbike helmets:
1 Try it on
2 Does it fit?
3 Yes - buy
4 No - back to 1
Consequently I've never bought mail-order, always in a shop.
Posted : 28/02/2023 8:40 am
I had the same experience as a11y up above, medium was way too tight and the large was too big. Usually a Large in most other brands.
Posted : 01/03/2023 4:04 pm
Pretty accurate imo or atleast it was last time I bought a POC helmet. 56cm sized nut got the S/M Trabec Race and fitted fine with a little room for a tighter fit, just recently got a Fox Dropframe and glad I tried I bought it from a shop where I could try it on as it Turned out I needed the Large. But yeah, stick a tape measure around your swede and if its an adjustable one just go with the size that correlates or head into an LBS to try some on for a rough idea, if you'd rather order it cheaper on the net just use the excuse "its not really the colour I want" or something
Posted : 01/03/2023 4:09 pm
I had to go for the larger size as well.
Posted : 01/03/2023 5:44 pm
I’ve been through this and concluded I can’t wear POC helmets
Me too. POC mips helmet in the 'correct' size. Felt OK in the shop, but in actual use, sodding uncomfortable. Gone back to a 15 year old MET helmet.
Posted : 01/03/2023 5:53 pm
