Anyone know how they size up? It's the Carnac croix range. I'm 58cm which is right at the top end of the medium and bottom end of the large.
Ta muchly.
Go up if you are on the cusp
I'm a 58 and I have the medium, it's a snug but good fit. Being mega picky I'd say that the plastic strap capture at the back pushes against your head (even with the little pushfit connectors set at the lowest level) just a little which isn't as nice as other helmet makes* that use a similar helmet shell design* but it was £15 so I'm not really complaining. If it helps I have a oval head shape rather than round.
*er...
Thanks fellas.
