Pivot bearings - wr...
Pivot bearings - wrong type?
3 Users
My son has a Commencal SX frame and bought a set of bearings for it - upon removing the existing ones I found that the bearings supplied are different. What's the deal? The bearings only contact a pivot on one side, so they would work, and they are the same diameter, so do fit... but there must be a reason Commencal supply the bike with one type... what will he get, just shorter life span?
Existing are 3802  15x24x7
supplied in the kit  680215x24x5
thanks!
Posted : 09/08/2024 10:59 am
3802 is 2mm wider, does the 6802 kit come with a 2mm spacer?
Posted : 09/08/2024 11:07 am
Yep, that's what I'm saying, the supplied ones are narrower. There's no spacer, but as the contact is only on one side, I don't think there needs to be? Just wondering how the performance/longevity will differ really.. or, of course, whether we should use them at all!
Posted : 09/08/2024 11:21 am
I'd stick with 7mm, even if the pivot bolts can thread in 2mm more, side load with wear the bearings out a lot quicker, probably make the frame feel flexier too.
Posted : 09/08/2024 11:39 am
Thanks. I'll see if I can contact the seller
Posted : 09/08/2024 11:43 am
