Pikes and tokens - ...
[Closed] Pikes and tokens - quick question...
9 Users
 wl
Will adding a second token to my Pikes mean that I can keep the softness, suppleness and small-bump sensitivity but make them ramp up more so they don't bottom out on drop-offs and very steep trails? They feel great as I have them now (low psi, no compression and one token) but they bottomed out with a nasty thump yesterday on a 4-5 foot drop. Basically I need them a bit firmer deeper into the travel, but don't want to lose their amazing sensitivity. Is another token the best way to go? Cheers.
Posted : 13/10/2014 1:35 pm
Yes, just reset the sag, you won't need quite as much air pressure.
Posted : 13/10/2014 1:36 pm
yes that's what ive done. im running much lower psi than recommended by RS and although I use pretty much all the travel they've never bottomed out harshly.
Posted : 13/10/2014 1:41 pm
Same happened to me, I run 2 tokens now and been better
Posted : 13/10/2014 1:59 pm
Yeah most people I've asked seem to have settled on two tokens. I'm running one and a half, since the previous owner thought two was too many (and presumably one not enough). I'm not sure I agree with hacksaw tweaking of expensive forks, but it doesn't seem to be causing problems.
I'm sure RockShox calibrate their shock pumps weirdly. I've never used more than about 75% of the recommended PSI. Just judge it by sag and feel.
I'm using 2 tokens with about 25% sag. Nice and smooth, never bottomed out harshly, just sort of firms up to tell you you're being stupid. I found that having the rebound a few clicks towards fast from the mid-point feels good too.
Posted : 13/10/2014 2:19 pm
I've ended up here: 25% sag + 2 tokens (60psi), LSC 7 clicks, Rebound 5 clicks.
Started out with no tokens, then one, then two, then one, then two. Sag has varied between 20% & 30%. Have had rebound slower and less low speed compression. The final setting seems to give the cornering grip I want and the right fore-aft balance when jumping - the extra low speed compression lets me preload harder as does the extra token, whilst the relatively low pressure keeps the front tyre tracking for good grip.
I think the extra spring progression means you can run less rebound damping because the rebound effectively slows down as the forks extend, so you get a good amount of pop when you push hard for takeoffs but you don't get that annoying understeery push from the front trying to unload mid corner.
Posted : 13/10/2014 3:11 pm
 Sui
cheif your such a geek, but i like your thinking. How [s]fat [/s] heavy are you kitted up, i've just put a token in my pikes on the spitty and it's marvellous. I'm an obese 86kg's kitted :wink:, so wondered if another token and reducing pressure may work more.. i had been struggling to get the pop i like..
Posted : 13/10/2014 3:22 pm
Sui, I think too much! I'm about half a stone lighter than you, pure muscle of course. 😉 The shock on my Spitfire is right back at the base tune and Keith's recommended 28% sag but it's taken a bit of fiddling to get the fork to perform as well for both cornering and jumping. As long as I think the set-up is great then I ride pretty well - and when I don't I descend into a spiral of useless mincing...
Posted : 13/10/2014 9:32 pm
I only run 1 click of LSC, found them way to harsh with anything more.
Posted : 16/10/2014 7:09 pm
I'm about 100kg butt nekked and I'm running 75psi And Currently one token. Seems pretty good for all round ridinG including drops up to about 5ft. Also felt decent with 2 tokens in
Posted : 16/10/2014 7:24 pm
