Hello all,
My time for a new bike is fast approaching (Banshee Spitfire), and I'm going to be putting some Pikeys on.
Whilst I know the bike is designed for upto 160mm, i'll be running a slightly odd combo of 26" frame with 650b forks (future proofing you see). Now normally a set of 150mm wouldn't upset the geometry too much, but there are some deals on for some WHITE 8) 160mm dual air's.
q1. can the dual airs be turned down to 150 or is it 130 or 160 only
q2. can you fit volume reducers in to the forks to lower the overall height of the fork?
ta
No you need to change internals of the dual air system, air volume is not adjustble either, unless you really need the travel adjust get the solo airs and change air shaft to give the desired travel
Cheers Loco, I was just about to press the dial button on the phone to you!
Think i'll stick with solo 150's and keep it simple (I just wanted white lowers 🙁 )
