Pike...Missing foam...
[Closed] Pike...Missing foam rings...maybe
7 Users
On Saturday I opened up.my rockshox pike select+ forks to clean and increase travel from 150 to 160. On putting them back together I realised the foam rings were missing from behind the dust seals. I have ordered some replacements but I just wanted to check that this isn't some new fangled seal system from rockshox? I.e. the rings definately ought to be there? There is definately a ring sized gap there still.
Posted : 23/05/2022 8:25 am
You should definitely have them
Were they s/h ?
Posted : 23/05/2022 8:45 am
Pretty sure they should be there - my 2021 lyriks definitely have them
Posted : 23/05/2022 8:58 am
Yes they should be ...
You can get a pack of 20 for about the same price and also set of 20 or so crush washers.
I find cleaning them is never a good option and if anything costs more in isopropyl than the cost of the foam rings. If you change oil frequently you can get several to a wiper seal...
Posted : 23/05/2022 9:44 am
Any links for bulk buying foam rings?
Posted : 23/05/2022 1:21 pm
I usually do eBay... they are after all just foam rings that hold oil...
I just looked and didn't see the "usual" (pre-covid??) ones.. plenty of 2 packs but not 20x... (which is only 10 changes)
Posted : 23/05/2022 1:41 pm
Can you fit them retrospectively then Steviextc? I bought a set of Enduro seals for my old Boxxers a while back and only realised that there were no foam rings in the set when I came to fit them many months later. I bunged them in without and just put a bit of lube oil in the gap they would have inhabited. Not sure it's worth adding them for the amount of use it gets (first ride in 3 years yesterday) but interesting to know it could be done.
Posted : 23/05/2022 1:54 pm
They were second hand but look nearly new. They hand had the travel adjusted previously. I'm guessing that's when they got lost.
speeder
you can definitely add them retrospective... that's what I intend to do
Posted : 23/05/2022 2:00 pm
It used to be a fairly common modification to ommit them and just pack the space between the seals with suspension grease?
Posted : 23/05/2022 4:52 pm
Yeah new ones are easy... more a knack than anything. Push a little past the gap then just ease back into them.
When you clean and reuse them them they seem loose some of their spongyness/springyness and it gets tricker to stop them falling inside.
Posted : 23/05/2022 5:05 pm
