Pike lower leg oil ...
[Closed] Pike lower leg oil , 5wt , 10wt , 2.5wt ? Which one?
4 Users
Looking at servicing 2015 Pikes, manual just says used Rockshox 0w-30. Here:
http://www.jejamescycles.co.uk/rockshox-suspension-oil-120ml-id83428.html?gclid=CjwKEAjwsMu5BRD7t57R1P2HwBgSJABrtj-RMddagLLtR_dPXhvgpKMDSjzcDDfwwv8D2hM_CZ1T9hoCcJbw_wcB#info
They list 3 different types though? Whats the difference in the wt values?
Posted : 11/05/2016 8:08 am
http://www.jejamescycles.co.uk/rockshox-pike-suspension-oil-0-w30-120ml-bottle-id87990.html
Thats the one for the lowers (not the damper)
Posted : 11/05/2016 8:18 am
heavier weight means a 'slower' oil - but the oil in the lower leg of a Pike is just a small amount for lubrication, so it doesn't matter a huge amount. I just use whatever I've got kicking around - which happens to be 10w at the moment...
Right! cheers. 😀
Posted : 11/05/2016 8:26 am
Wt is a measure of viscosity. Pikw use nice runny oil for maximum slipperiness (and splash lubrication) make sure you use a lubricating oil.
Posted : 11/05/2016 8:41 am
