Just wondering about the new 2021 debonair airshaft and if the pike and Yari shaft is the same and interchangeable?
Steve.
Yari and Lyrik parts are interchangeable, then its Pike and Rev. C1 airshaft is the most up to date:
https://www.tftuned.com/2021-c1-debonair-air-spring-upgrade-kits-lyrikyari-pikerevelation-2018/p3851
well - actually that's not quite true - original A1 solo air shafts can be used on lyrik, pike and yari - but pike to yari yields different travel - yari to lyrik gives same travel
Not for the 2021, they are different parts.
https://r2-bike.com/navi.php?qs=2021+debonair+air+shaft&search=
cx_monkey
well – actually that’s not quite true – original A1 solo air shafts can be used on lyrik, pike and yar
That depends - there were different parts for boost and non boost Pikes, so compatibility was tricky.
Cheers all.
Sucks a bit as I've got two pike airshafts in the garage.
Well then try it and see what happens...
You might be able to make it work by swapping top caps around.
I'll have a look mate. Got a set of 150mm yari on new bike which only measure at 140mm so not sure if fitted with new debonair shaft or not.
Page 7
Nope, they're definitely compatible parts - see part numbers here:
(this includes 21 product too, despite the file name...)
