Can you anyone confirm that the only part required to convert a 140mm Pike 29er fork to 120mm Travel is a RockShox Pike Air Shaft Solo Air 150mm Travel 26 / 120mm Travel 29 please?
Oh and 4 tokens.
For anyone else interested, i can confirm that it is.
Yes the 26" 150mm/27" 140mm/29" 120mm air shaft are one and the same unit, you'll want some 0w30 lower oil as well to do the job, we obviously have all this in stock 😉
Loco - in case you read this before I call tomorrow what air shafts do you stock? I'm after a 150mm 29er version and was about to order from a shop in the States.
I can recommend Loco - he converted my 140 29er Pikes to 120 😀
Yetiman, can machine one to that size, will have to double check we have a 160mm to use but 99% sure we have.
Thanks Clink 😀
Great stuff 🙂
I'll give you a call tomorrow morning.
Great service again from Loco Tuning. Spoke to them on Tuesday and confirmed I wanted a 150mm air shaft, got a call yesterday to say it was ready and it arrived in the post this morning. 8)
Why would you want less travel?
To not screw up the handling on your bike.
