Pike 29er RCT3 Solo
[Closed] Pike 29er RCT3 Solo
6 Users
Does anyone know if the 29er Pike RCT3 Solo can be lowered to 110mm? I know it can be bought at 120mm. I also know the new Fox 34 can be run at 110mm and was just wondering if the same can be done with the Pike.
Cheers,
Matt
Posted : 14/12/2015 7:09 pm
I asked on CRC on the Pike travel change air shaft reducing from 140 to 120 which can be done, not sure about 110 though.
You could ask them.
Posted : 14/12/2015 7:42 pm
I "think" LoCo said he can custom cut the air shaft to your desired length (eg: 111.5mm).
Posted : 14/12/2015 7:56 pm
 awh
TF Tuned lowered mine to 120mm. There were two options, a different air shaft or modify the existing one. If you have it modified they can do it to any length travel.
Posted : 14/12/2015 8:45 pm
Dont quote me on this but the 140 26 shaft should do it. Part code R8026010
Posted : 15/12/2015 1:10 am
 LoCo
Yes we can reduce the travel to pretty much any length you wish 😀
Posted : 15/12/2015 10:53 am
That's great folks, thanks for the replies. I have bought a Pike 120mm for a Stanton Sherpa frame. I just wanted to check it could be reduced if I fancied it. I'll try it at 120mm and see how it goes. LoCo - I'll give you a shout if I think it needs to be reduced.
Cheers,
Matt
Posted : 15/12/2015 12:25 pm
LoCo,
Out of interest, if I was to go to 110mm with the pikes and hated it, would it be easy to go back to 120mm. Excuse my ignorance in this!
Cheers,
Matt
Posted : 18/12/2015 9:00 pm
 LoCo
Hi Matt, yes no problems, you'd just need to change the air shaft to one of the desired travel.
Posted : 18/12/2015 9:06 pm
Thanks LoCo - appreciated!
Posted : 18/12/2015 9:41 pm
