Just bought a little fiat doblo cargo van, how do you transport your bike safely.
Pics would be great.
Got a doblo cargo. No pics handy but bike goes in fully at a slight angle. I mainly use a seasucker mount bolted to the floor and the forks in the mount. Keeps the bike super secure.
I bought one of those alloy four bike racks front wheels sit in place then Bungie cords hold back wheels in place,got four bikes in plus gear and supplies easy and I have a Kangoo Maxi
i have a doblo van
ive kitted out the right side with some shelves that you access from the right sliding door, and that extend into the rear for tools and helmets.
if i take one bike it goes in rear wheel first if im taking it out via the rear, and it goes in front wheel first if im taking it out from the side
i can get 3 bikes in, two withe wheels at opposite ends and one with front wheel taken off.
pictures tomorrow.
mine is the james bond Doblo.(ask if you need to)
Strap it to the side... nothing more annoying than the thought of having a van with all the load space taken up by a bike and nowhere to change/sit/play scrabble!
STW issue T5 fully laden with kids, bikes etc on various trips... theres 3 bikes somewhere in there...
[URL= http://i219.photobucket.com/albums/cc310/jenga101/2015-03-28%2012.20.02_zpsexrpshat.jp g" target="_blank">
http://i219.photobucket.com/albums/cc310/jenga101/2015-03-28%2012.20.02_zpsexrpshat.jp g"/> [/IMG][/URL]
Hard to see here but the forks are bolted to the floor. You can see my other mount at the bottom of the picture so I can get two bikes in and still have loads of room
I had a temporary bed/bench in but that's been taken out until i finish lining everything then I'll be putting a better version in
Boardinbob cheers for the pictures, gives me some ideas on how to lay out mine, like the fork mount.
As above, I've got two of those mounts in my Caddy, could probably get four bikes in.
Have ordered mount for forks, just need to order self inflating mat from alpkit for comfy overnight stays
[URL= http://i1050.photobucket.com/albums/s419/mike_moore4/Mobile%20Uploads/20150606_140209_zpsz619fpyr.jp g" target="_blank">
http://i1050.photobucket.com/albums/s419/mike_moore4/Mobile%20Uploads/20150606_140209_zpsz619fpyr.jp g"/> [/IMG][/URL]
Can fit up to 8 bikes plus camping kit in the back of a SWB crew cab Vivaro.
[URL= http://img.photobucket.com/albums/v632/MikeyC/bike/14FCE473-03E1-4A3A-B19A-7830E3B57E12_zps8b2zmj31.jp g" target="_blank">
http://img.photobucket.com/albums/v632/MikeyC/bike/14FCE473-03E1-4A3A-B19A-7830E3B57E12_zps8b2zmj31.jp g"/> [/IMG][/URL]
My Peugeot partner with 3 bikes in. 2 29ers and a 26" all with wheels on. Usually just bungee them to the sides.
As above. Bungees. Lots of bungees.
[URL= http://i452.photobucket.com/albums/qq245/SimonB_09/VW%20Kombi/IMG_20150815_104043_zps0uhvgair.jp g" target="_blank">
http://i452.photobucket.com/albums/qq245/SimonB_09/VW%20Kombi/IMG_20150815_104043_zps0uhvgair.jp g"/> [/IMG][/URL]
Citroen Berlingo Van swb
[URL= http://i1073.photobucket.com/albums/w396/wolfenstein782000/20140913_220908_zpsurvqvopf.jp g" target="_blank">
http://i1073.photobucket.com/albums/w396/wolfenstein782000/20140913_220908_zpsurvqvopf.jp g"/> [/IMG][/URL]
ps. don't sleep inside like i do in a september its freezzzzing 😕
Cheers for the pictures, going to have a go at the 15mm maxle holder from seasucker. Might reconsider sleeping in the van. 😀
Man up. Bivvying in Scotland in January is cold, a van in September is luxury!.
Nobeerinthefridge. I'm not as hard as you! 😆
We've got a Doblo car/people carrier thinger, we took the back seats out and we can get four bikes in the back ok. No room for people with the bikes in there though!
Mco1 or anyone, is that partner the SWB one?
Funkhouser - Looks like the SWB, mate has a SWB berlingo (same size) and bikes fit in ok with wheels on and handlebars turned.
Not the same van - but this is what we do in ours - just need to replace the bike rack with a slightly wider spaced one as the tyres I'm using now don't go in the rack 🙄
It also looks like the bikes need washing and the van needs tidying - that's tonights job.
BoardinBob, bit OT but how do you find that 12V 'power' washer? i've got one that is so poor i don't bother taking it , but if your's is okay i might give mine another look to see if its blocked?
Mine is great. It's an Airace Driving Waterman. Works perfectly and is very well built.
[URL= http://i680.photobucket.com/albums/vv167/porter_jamie/457825_10151049583803669_1497748334_o_zpsjo6cbk1x.jp g" target="_blank">
http://i680.photobucket.com/albums/vv167/porter_jamie/457825_10151049583803669_1497748334_o_zpsjo6cbk1x.jp g"/> [/IMG][/URL]
heckler, spicy, camber, stumpy, another stumpy and a 456, plus bags
[url= http://www.argos.co.uk/static/Product/partNumber/3916146.htm ]folding bed[/url]
These are good for sleeping in the van, easy to put up and down and extra space when needed.
Great thread - v. interesting to me too. Does anyone have any pics of the Doblo with the back seat still in and bikes in the back?
Thanks Dick!
I like the look of this one (scroll down a bit)
[url= http://www.vwwatercooled.com.au/forums/f136/multivan-rail-58877.html ]bikes up at an angle[/url]
Following.
slowbloke - Member
Can't you just bend them out a bit? I've got a Fiat Doblo Cargo with a half bulkhead and I fitted a couple of those cheap bike stand things onto the bulkhead. Shove the back wheel in and turn the bars 90 degrees and you're done.
They don't appear to be terribly bendy - the welds cracked on the one I tried so I just ordered some new ones (£10 each so fairly cheap) - 2 individual ones this time to allow for more flexibility in placement.
I just bungee mine to the side of my Vivaro and use pipe lagging or foam sleeping mats to space them. If it's just one bike I lie is flat on the floor.
If the double bed is built up its either one on top and one under flat are wheels off and stowed across the van behind the bulkhead for long trips across Europe.
I wouldn't have bought a van that required taking a wheel off to get the bike inside, if that was the case, I'd have kept the civic tbh.
If my van wasn't converted and it was still a van then I'd stick the bike in but for the way I use it, having the bike mounted in the rack is neater and securer
Mine is converted too Bob, possibly slightly bigger though, so I can still fit two bikes with wheels on as well as the bed. Whatever you choose, there's always a compromise though.
Edit - yours is a tidy job btw.
Small van fixed bed - do you sleep in it alot ?
My bed lays flat on the floor the 11months of the year when its not in use and i just stick it up on the storage boxes with my gear in when in use. Then i can stick 3 bikes in wheels on for the rest of the year.
Not really that small Terry - LWB hi top tranny connect. A small van in my mind, but useful enough. I have a bed in there that extends width wise to make it about single bed width. It's great, and it means I have all the storage beneath.
Autobox berlingo ? How does that drive...... Interest is piqued,
Trail_rat
Once you get use to it, faultless and very stress free, still has the flippy paddles for semi auto, but it's not a sports car and never use them.
35 years of driving and got to the stage that i was completely sick and fed up with changing gear with a clutch pedal !
The old days of auto boxes are long gone and the auto box of today have certainly upped their game.
what engine combo do you have ?
i must admit recent autos have impressed me to the point of fancying a dabble with the exception of the ZF 7 speed box in the parents range rover..... its like having a serious dose of turbo lag while the box plays catch up.
Can you fit bikes in a LWB T5/Vito/Vivaro etc. with a row of seats behind the driver and passenger seats wihtout breaking them down? I'm guessing you couldn't in the SWB versions of those vans?
Trail_rat
I went for a 2014 XTR E-HDI 1.6 ltr and "Town" driving i'm getting 50 mpg.
To be honest, yes there is some lag with the auto box / turbo at junctions, but once you get use to it and the whole way you drive changes to a stress free environment.
I have gone from 9 years driving a Audi Quattro onto the Multispace and i can not fault it, apart from one major problem, it's not brilliant on thermal coffee cups fitting and have had to adapt using a plant pot !! 🙄
You can fit a motorbike behind the second row in a lwb t4. A 1000cc one even. I have had 5 or 6 in with the wheel in with no dramas.
Edit add mtb that is!!
wobbliscott - Member
3 bikes with wheels on in the back of my T4 swb behind the second row of seats. Larger bikes or 29ers might not fit but medium/sml 26ers are fine.
Thanks chaps - that looks OK, I can't imagine i'd want to be carrying more than 2 at a time so fitting diagonally isn't an issue. Looks pretty doable in a LWB. Trying to talk the wife into swapping out the SMax for a van, but it would need to be able to carry passengers in the back. Would be nice to be able to go biking and get changed in the van rather than getting my bottom out in a public car park, and have the ability to make hot drinks or even food on bigger days out either biking or with the family.
That's exactly why I went for a LWB, to get my bikes in whole. I ride XL or XXL and they don't quite fit in a SWB. I can also - just - lie out straight in the back even with the second row of seats in place.
I can fit one (for sure) or two (depending on wheelbase) bikes fully built in the rear of a SWB crewcab Vivaro/Trafic.
No room for sleeping obvs.
picked up the SWB Peugeot Partner this weekend, took my bike with me to view it and it fitted in a dream with both wheels on! got it home and stuck my other two in just for fun. three full bikes no problem, not that ill ever be required to carry that many. first day on duty yesterday! bike, gear, dog and four new wheels...
[img]
[/img]
was previously planning to get some racking along the near side back panel, but looking into it its gonna run to about £150 and im not sure i really need it... hanging stuff off bungee washing lines seems to work ok.
does anyone reckon racking is worth it or have any other good tips for maintaining a bit of organisation back there...?
I used to have some netting made from elastic bungee style material on the wall of my old van and it was great for stuffing clothes and stuff out the way. Tales up no space and rattle free
A bed with storage boxes below. I can fit two bikes with wheels in easily next to it. (though if I'm sleeping in the van, I'll never have 2 bikes!).
Bed doubles up as a nice seat for tea and biscuits at events too, out of the rain.
Connect LWB with high roof btw.
I like that^
Forgot all about this thread I started!
Must get some pics up of my horsethief in the new doblo.
speedstar - liking that a lot. What size of bike is that? I always assumed the T5 was a tad narrow to fit any bike across the way in the back.
LWB T5 with extended length (an extra 15cm) RIB seat/bed in the back. Still possible to carry 2 passengers inside the rear but middle seat unusable. Other bikes go on rear door rack. Bike is XL 29er, wheel just pokes a tad between front seats.
[url= https://farm9.staticflickr.com/8788/16889168389_26485f3688_c.jp g" target="_blank">https://farm9.staticflickr.com/8788/16889168389_26485f3688_c.jp g"/> [/img][/url][url= https://flic.kr/p/rJrpmr ]2015-04-02 Van bike rack (1)[/url] by [url= https://www.flickr.com/photos/a11y_m/ ]Ally Mitchell[/url], on Flickr
It's an XL A11y would you believe it! liking the angled fork holders though. Might work for mine!
Anyone having a trouble fitting a 29erin a new doblo, seems the bulkhead sits in the load area quite a bit
Stole this idea from Sazter when we were on a ride. Cannibalised Ikea shoe racks
Cut these up: http://www.ikea.com/gb/en/catalog/products/20251974/
Bit of gorilla tape along the upper and lower edges to reinforce them. Screw them to the ply. Brilliant storage and deceptively roomy.
Sooo much envy.
I love vans.
I've let mine fall into a bit of a state but this is motivating me to try a fresh new layout.
Like the shoe rack idea.
Could even use it to keep shoes in.
4 big bikes, kit and 4 adults in a Navara with not the most useful shaped hardtop on the back...
[url= https://c6.staticflickr.com/8/7436/12371140405_ae52fcc516_b.jp g" target="_blank">https://c6.staticflickr.com/8/7436/12371140405_ae52fcc516_b.jp g"/> [/img][/url][url= https://flic.kr/p/jRck3e ]Untitled[/url] by [url= https://www.flickr.com/photos/85252658@N05/ ]davetheblade[/url], on Flickr
I see a summer holiday mini project going on for my Vivaro. Love the shoe rack idea.
I bought a load of elastic nets too, but have yet to put them in the van.
Liking Tomaso's double height choice.
Resurrection of this thread, now that I've got a lefty it's not practical to be removing the front wheel for transporting. Anyone any solutions for a lefty in a van.
