Press fit bb92 to b...
[Closed] Press fit bb92 to bsa BB: advice please
4 Users
 TomB
Evening all. I’ve just bought a new cheap cube frame for my lad from bike discount as he is outgrowing the current one. I intend to transfer all the components from the old to the new, but this one has a PF bb92 BB and the current one is BSA threaded, in which I use a Shimano square taper bb and 152mm cranks, which I’d like to keep. Can I use one of the adapters (eg sram, FSA) in the PF bb shell to continue using the square taper bb?
Stealth ad- 14” cube hardtail frame will be available late January, all going well.....
Cheers!
(Edited, bb92, not pf30
Posted : 23/12/2018 5:52 pm
 TomB
After a bit of digging, it seems converters are available for pf30 but more difficult to track down for bb92- there is This On eBay?
Posted : 23/12/2018 6:07 pm
Never seen one, but they may be out there - effectively it’s a 41mm dia bush with a 35mm thread, so not a lot of metal/easy to distort when installing
Posted : 23/12/2018 7:42 pm
Can’t see how that’s going to work without milling 19mm off your BB shell. It’ll convert the BB bore to being the right diameter and thread to fit a BSA BB, but the shell will be way too wide. Also - two independent sections means that the Bb you thread into it will be both unstable and a pain in the ass to remove.
Better just to fit the right BB and chainset.
Posted : 23/12/2018 7:48 pm
 TomB
Yup, looks like new chainset time.
Posted : 24/12/2018 12:39 am
Any of the wheels manufacturing bb!s that would work?
Tried adding the link but can't get to on the phone...
Posted : 24/12/2018 3:31 am
https://wheelsmfg.com/bottom-brackets.html
Posted : 24/12/2018 3:38 am
