Looking at 2 jackets.
Which would be more breathable?
Pete. definitely pete.
Paclite is OK but it is not very robust and also, being so thin, it transfers the cold from rain to your body so feels much colder than a thicker goretex jacket.
Same with Active Shell.
How about pertex , is that better than pete?
What kind of Pertex? That's a brand name covering a few different fabrics. If it's a fully waterproof version then it might be about the same as Paclite. A wind/showerproof version will be more breathable.
I'm not buying a jacket made of pete.
it sounds a bit weird, and not massively waterproof if I'm honest.
Rab fuse pertex or a gore paclite.
gore paclite and some ducktape to stick the rips back together because you rode near some brambles.
My paclite jackets lasted about a year and a helf before they leaked on the shoulder where they had been worn by the strap from my messenger bag whilst on my short commute. The Active Shell might be slightly better but the material has still frayed open on the ridge by the hood peak, and that is mostly commuting as well.
It'll be waterproof just as long as you manage to keep the subcutaneous fat layer. Not very breathable though, and the shelf life will be quite limited..
