I'll be spending some time in Edinburgh in mid-March and want to check out the local riding. Ideally riding from Edinburgh itself with a rented MTB or gravel bike. The Pentlands look like the most fun and I've found some great routes by searching the forum. However, what are conditions like coming out of winter? With the amount of rain we've had recently mean the Pentlands will likely be a sloppy muddy mess that I shouldn't ride in case of damaging the trails?
Ride. Pentlands are nice if you've not ridden there before. Certainly some trails get muddy, like anywhere in the UK in March, but it's just a question of getting some specific route advice.
It's a wide, mixed area, it's not like the whole place is a winter swamp and everywhere is bad.
I got back from a ride up there half an hour ago and one of the guys working on the flat next door said I looked minging.
It's mucky up there just now. Not unrideable but be prepared to get filthy. I wasn't bogged down anywhere and it's really just a thin coating of mud.
It's getting to the time of year when the MTB routes are enjoyable again. But then, it could snow next week. It is Scotland.
Let me know when you're up, if I'm about I'd be happy to hook you up with a bike and show you round if I'm about.
There are some routes that historically (and ideally) wouldn't be ridden in winter but since lockdown with foot/tyre fall increasing, what used to be ribbons of singletrack are now anywhere from double width to a sprawling mess. You can get a decent gravel-ish route in avoiding these but if you want more interesting/fun MTB routes you'll end up hitting them.
For me its pick and chose your routes when its wet - and that is the guidance for the LRA. there are paths I will not ride when its wet but that still leaves plenty of paths that are perfectly suitable
Yeah, to add - routes are definitely seasonal. There's a few descents I won't go near for much of the year.
The main seasonal route I know of in the Pentlands is the Black Hill singletrack, which should be avoided until the ground starts to dry out around Easter. Given how deeply eroded the first bit is I'm not sure if that's still adhered to by many, but the boggy bit in the middle of that track would be quite unpleasant if you rode it in the wet bits of the year.
There's a few bits you can ride more reliably year-round as some of the trails are gravelly rather than muddy (though still expect swamps in places if it's been raining). In March you'll likely have avoided the worst of it, but you never know in this current late Winter. I haven't been recently but I am up there loads and really got to know the whole range during lockdown.
- Maiden's Cleugh is a blast of a descent: largely gravelly and rocky at the top but wetter at the bottom. Gets a lot of footfall so whilst it is easy to go balls out fast you just need to be careful of walkers. Doable on a gravel bike and a fun engaging climb up from the town side to the saddle too, though it's now exceptionally eroded and gets muddy as hell.
- Black Hill Traverse (heading Eastwards) has some atrociously boggy spots in between the gravelly / rock sections but this is one of my favourite trails in the Pentlands. In places it feels like it was designed for bikes - really good fun. More of an MTB one and only if it's been dry for a week or so before.
- The 5 peaks route is good fun and feels like a bit of a mountain day. I would probably avoid the westernmost peaks (East Kip and West Kip) especially after bad weather as it's a lot of up and a big approach for fairly crap muddy 30 second downhills. But it is easy to hike up to Scald Law (highest one in the range) from the end of Loganlea reservoir where the trails improve into better drained gravel paths (as long as you avoid the shortcuts which a lot of people take). Some parts are actually quite steep and mild techy in places but all rideable. The last descent towards Glencourse down from Turnhouse Hill is fantastic fun (though can be boggy in places and popular so go easy and ride responsibly)
- A good gravel / mild XC route is starting at Threipmuir Reservoir (nice cycle from town or following paths from Bonaly), and heading up to Bavelaw castle via a very steep but short road called Exponential in cycling circles. You can then go down through Green Cleugh and the Howe (very scenic and lovely rough gravel path descent through a deep glen ending in a river crossing) to meet the road end at Loganlea. Ride down the road until you get near the end and take the massive gravel road climb to Fala Knowe below Castle Law. It's all fireroad but steep and loose in places so a bit of a workout but great views at the top. You can then either go down the other side of the road towards town (again, steep and loose so have good brake pads) or turn left and follow the hills westwards until you want to come off (plenty options - some muddier than others).
- Similarly, follow the same start to Bavelaw castle as above, but follow the road right to a farm, go through a gate and you're on a double track called Yellow Brick Road, stretching out ahead for a couple of kilometres. This is great fun up and down, rocky and rough in places. In the wet it gets too wet-clay-ish but an absolute blast after a few dry days. At the end of that you could just double back, or turn left up to the Boarstone up an easier gravel climb and down to North Esk reservoir. You can ride straight through to Carlops on the South side of the hills from there if you like, but leaves you in the weeds a little bit with a long way back to Edinburgh. There are some more routes from North Esk reservoir but all a bit obscure and not incredible fun unless you like MASSIVE steep gravel roads. The best stuff imo is in the eastern / "main" range nearest town.
*jings sorry went off on one there. Point being is that there are spots that you won't get too clarty. Just try and avoid paths that are largely grass desire paths (Harbour Hill north traverse being the worst culprit).
Just to add on - if you just have a couple hours free of an evening a couple laps of Braid Hill is great fun and just a 20 minute ride from the middle of town. Quiet in the evening and dries quickly after dry weather. Doable on a gravel bike but theres a couple little rock roll / mild rock garden things on the main descent from the top and funner on an MTB. I do this all the time for a little XC loop. Generally quiet in the evening but watch out for speed round blind corners as there can be horses or lost golfers.
Pick and choose your route and it's great year round. I've been up top in deep snow and winds where my bike became a kite.
The 5 peaks have some steep bits (the kips and turnhouse)
The descent to the North side of black hill to black springs is very eroded and very boggy in the middle. I hadn't ridden this in a while and I was shocked by the water erosion. (one rut towards the top must be about 1.5m deep (man dimensions))
The descent from the capelaw/allermuir/castlelaw path towards glencorse is fun but also boggy most of the year. Good as a climb for 1 week in summer.
What part of Edinburgh are you staying in?
I quite enjoy the latest water eroded parts on black hill - makes it a bit more challenging and techy and I find the boggy parts are (were at least!) avoided quite well by staying well right in that flat bit. I ran the route in December the last time I was up there and I remember a much dryer path to avoid them.
That rut is absolutely wild though, I was amazed it was gouged out so quick. Must have been a hell of a run-off...raises questions about how ridiculous the heather management is higher up the slope.
Glad the little flat rock booster is still there.
Thanks for the great advice all. Looks like it should be fine as long as I base my ride around the gravel ways rather than trying to hit all the trails then.
Following the advice here and elsewhere, I've planned out a big ride which includes most of the stuff mentioned: https://www.komoot.com/tour/1427827672
I'll be staying in the Haymarket area. Biketrax at the end of the canal rent out hardtail XC bikes so I've plotted the route from there.
Had a great time with @munrobiker who was kind enough to show me around, lend me a bike, and put up with my timid descending. Lucked out with the weather
- Puke Hill: an appropriate name
- Maiden’s Cleugh: indeed a blast of a descent
- Castle Law: loved this climb, watch out for the soldiers firing blanks!
- Dreghorn (descent): need good brakes for this!
