Pensioner Question ...
[Closed] Pensioner Question -Old E4 caliper on Mini lever.
2 Users
Im cobbling together some old brake sets, as everything's just wasting sitting there like Ebeneezer's hoard 😕
I've been servicing the first E4 or Enduro 4 from I think maybe mid 90's and I was using a mini lever. Given the mini lever was the next from the open pro(and sport) anyone know if they'll work together ?.
Be a better brake for the front of my commuter, and it gets it out and in use, which is what they're for really, not hoarding over 😆
Posted : 11/08/2020 11:42 am
If you can physically join them, nothing weird like different diameter hoses or anything, then I guess what you need to work out is how much fluid one pull of the lever moves and how much is required to move the pistons at the other end the desired amount. If these are similar I can't see why not.
Both require DOT fluid too.
If you can't measure/find the info this I would be inclined to put it together, stick it on the rear of a bike on a turbo and see what happens
Posted : 11/08/2020 1:20 pm
