Penmachno From Betw...
[Closed] Penmachno From Betws y Coed
8 Users
Shall be stopping in Betws y Coed  between Christmas and new year and was wondering if it’s possible to get at the Penmachno trail off the A470 by bike. Will have to ride there from Betws y coed, fancy having a go but didn’t fancy riding along the A5 too far to get at the trail head.  Don’t mind joining part way round if it’s a easier from Betws. Ta in advance.
Posted : 16/12/2019 1:29 pm
You’ll only be on the A470 and the A5 for a mile or two. Think you can B road it but it won’t be direct. Depends how happy you are riding those roads in the scuba gear you’ll need at Penamchno.
Posted : 16/12/2019 2:01 pm
Once your turn off at Conwy Falls cafe it’s a quiet road and not too far. Have fun it’s a great trail unless your made of sugar then you may melt. Would be interested if there is a back way in, local local may know.
Posted : 16/12/2019 2:12 pm
Its not far, I do it quite a lot on my road bike, not the trail, I just ride past the car park. Anyway, A5 up towards the cafe, its a good climb on a road bike, not steep, but its busy. Turn right at the cafe (Falls Cafe I think). Then follow the road down, just a handful of miles.
Not sure if it helps but you can get on to the Marin Trail directly at Betws-y-Coed.
Posted : 16/12/2019 2:16 pm
+1 Marin is now called Gwydir Forest, easier access if you're just after a quick blast.
Posted : 16/12/2019 2:22 pm
Cheers Guys. Have done Gwydir a few times but never Penmachno. Looking at Satellite view there’s a road in off the 460 before  Glan Lledr Holiday Cottage. Just wondered if I could get at it from there.
Posted : 16/12/2019 2:29 pm
Looked into this myself before but never needed to do it-looks simple enough,fireroad up just off A470 to pick up most Northerly part of Penmachno top loop.......
To Penmachno
Posted : 16/12/2019 2:47 pm
Looks drier from space...
Posted : 16/12/2019 2:54 pm
Shall have a look. Guess there will be some tyre tracks, unless they’ve been washed away!!! Thanks.
Posted : 16/12/2019 3:45 pm
If you get lost, listen out for the sound of running water - that will be the trail.
Posted : 16/12/2019 3:49 pm
Head up the small road that crosses behind the Cotswold outlet shop at the South end of B-Y-C (past the Vagabond Bunkhouse). This is a pleasant ride that follows the river on very quiet roads (also a cycle route of some sort). It brings you out onto the A470 after it makes a dog-leg under the railway. There's a cycle path of sorts along the A470. This will take you to the bridge you've seen after about 500m.
I haven't ridden up to Penmachno from there myself, but know people who have - They report that it becomes very disorientating in the forest - there is a maze of fire roads, some of which appear to be going in the correct direction, but end up in dead ends. Their advice was to plan a route using google earth / Strava, etc. It's pretty steep from what I understand, and retracing your path gets tiresome quite quickly.
Posted : 16/12/2019 6:55 pm
