pedals not powering...
[Closed] pedals not powering rear wheel properly?????
6 Users
tonight i noticed that occasionally when i pedal it is taking about half a pedal stroke before it engages and turns the rear wheel if that makes sense????
I am assuming its my free-wheel that is on its way out or is there some way to sort the problem?
its a lapierre spicy 316 2010 if that helps link to spec below
http://www.evanscycles.com/products/lapierre/spicy-316-2010-mountain-bike-ec020976#features
Posted : 12/03/2013 11:12 pm
Pawls. Possibly just need a clean out - last time it happened to me they were full of gunk n stuff. Flush out, relube. Refit.
(Watch out for teenie springs)
Posted : 12/03/2013 11:15 pm
freehub body is on the fritz innit. its shimano so easily replaced. part is about 15-20quid plus fitting. will also benefit from new bearings. if its done some miles it may well need new cones too.
Posted : 12/03/2013 11:17 pm
Probably best off just buying a whole new rear hub, often cheaper than the aftermarket freehub. Then you can use the new bearings and cones aswell
Posted : 12/03/2013 11:21 pm
Good point Mr Taylforth. Just be careful to get exactly the same hub (m525) because the seals are different. Not all deore hubs are made equal.
Posted : 12/03/2013 11:24 pm
yeah but then you might as well spend that money on a new wheel and keep a spare rim.
tbh OP, just buy a new bike and keep your current one for spares.
Posted : 12/03/2013 11:26 pm
lol float that escalated quickly lol
well i might aswell give it a quick clean and relube as it seems simple enough, if that doesnt sort it new freehub and will prob redo all the rear cassett front rings and chain whilst im at it ready for summer, was plaing on holding out with all the snow still falling but meh might as well nut up
Posted : 12/03/2013 11:32 pm
If it's an M525 Deore hub you're after, beware, the spec appears to have been cheapened. The original M525s had external seals, looks like the current M525s do not have the external rubber seals, and perhaps there are other differences too.
Posted : 12/03/2013 11:35 pm
just a quicky am i looking at something like this????
http://www.chainreactioncycles.com/Models.aspx?ModelID=78987
Posted : 12/03/2013 11:36 pm
Hmm, I think that would more expensive, smart arse.
Posted : 12/03/2013 11:42 pm
