Pedal washers with ...
Pedal washers with SLX 12 speed cranks?
12 Users
4 Reactions
I got the OE bagged cranks a few weeks ago for a build. I can't remember them coming with pedal washers, or would I have lost them? Or are they just not needed or not included?
My NX cranks came with them.
Should I fit some to the SLX cranks? (Time MX4 pedals).
Thanks.
Posted : 08/11/2023 4:10 pm
I think that's a sram thing... for some reason...
Posted : 08/11/2023 4:18 pm
Pedal washers only really required where you have spanner flats on the pedal spindle that face the crank - as Time pedals generally have a round spindle, not really needed.
Posted : 08/11/2023 4:21 pm
Thank you so much.
Posted : 08/11/2023 4:24 pm
I find that adding washer help to reduce damage and stops the pedal spindle 'sticking' to the cranks.
Posted : 08/11/2023 6:35 pm
Straight in the bin every time.
Posted : 08/11/2023 6:49 pm
I find that adding washer help to reduce damage and stops the pedal spindle ‘sticking’ to the cranks
I've had washers, I've had no washers (usually). Never had a stuck pedal. I do grease the threads though
Posted : 08/11/2023 6:53 pm
I don't think modern Shimano cranks come with them, some older ones did.
Posted : 08/11/2023 7:30 pm
 csb
I think I asked this a while back because a set of Octalink cranks (that use a cartridge bb) came with some washers. I was told they were bb washers not for pedals!
Posted : 08/11/2023 7:33 pm
10 speed slx used to come with them, or at least the double with bash guard did but my latest 12 speed single ring slx didn't.
I personally prefer to use them as pedals can start to dig into soft alloy crank arms
Posted : 08/11/2023 7:41 pm
kelvin and kelvin reacted
Once you've had a pedal you can't get off a crank arm you'll always use pedal washers...
Posted : 08/11/2023 8:26 pm
I fit them to all of mine after having to cut a pedal out of a mates crank 20 years ago.... A few quid on ebay for a box of 20, why wouldn't you use them?
Posted : 08/11/2023 9:00 pm
why wouldn’t you use them?
Because in 40+ years of doing my own bike maintenance
I've had stiff ones, never stuck though
Posted : 08/11/2023 9:10 pm
Once you’ve had a pedal you can’t get off a crank arm you’ll always use pedal washers
Why would a washer make a difference?  Its the threads that seize from a lack of your favourite assembly lube and over tightening
Ive never had a stuck pedal on anything i assemble.  Most of the pedals i have had have no washers anyway.  Copaslip for the win.
Posted : 08/11/2023 9:16 pm
Because I've built or repaired literally thousands of bikes and I've never had a pedal get stuck, or had to cut one off.
Not one that was caused by the lack of a tiny washer anyway.
Posted : 08/11/2023 9:34 pm
Thanks again. I put the pedals on and for the first time of my life checked the recommended torque by both Shimano and Time.
35nm!
That sounds mad.
So I tightened by feel as I have been doing for 35 years with Time Atac pedals.
And then I checked and it was way under 10nm. No chance I am going anywhere near even 10nm, it would be a bugger to take off. I never had a loose pedal. Just luck?
Posted : 10/11/2023 7:23 pm
pedals self tighten. I do them up to way under 35nm, never had one come loose. there is no force to loosen themunless the bearings seize. 10 nm sounds about right to me but I don't use a torque wrench.
Posted : 10/11/2023 8:40 pm
10 nm sounds about right to me but I don’t use a torque wrench
Likewise, you just get a feel for it.
Apart from the carbon bars I've just fitted, but even using a torque wrench I knew it was thereabouts to where I would have gone anyway, so didn't really need to bother
Posted : 10/11/2023 9:20 pm
I honestly don't think ive ever used pedal washers. Nor have I had a stuck pedal, or a pedal coming loose. And I don't own a torque wrench
Bit of lube on the threads, spin them up tight then a nip with spanner or hex. Job jobbled
Posted : 10/11/2023 9:43 pm
tjagain and tjagain reacted
