Pedal bushings avai...
[Closed] Pedal bushings available where?
3 Users
I'm not sure I can get the bushings needed for my pedals in the uk, can I use alternative bushings? If I can how do I go about sizing them. Bushings in question are below
https://www.straitlinecomponents.com/products/pedal-rebuild-kit?variant=6620794947
Posted : 21/04/2019 7:27 pm
Daytime users, in the exploded drawing it says I need igus bushings and thrust washers I presume made of nylon or something similar.
Posted : 22/04/2019 8:01 am
If buying what you need from the states as per your link above, then its worth looking at rebuild kits for other manufacturers pedals.
As long as you know the size/spec of the bushings you need you can then compare and may come up lucky.
I did this with a old set of CB Candy pedals which rebuild kits no longer seem to be available for, found some bushings and bearings for a Nukeproof rebuild kit which were the same size.
Posted : 22/04/2019 11:23 am
Yeah I have seen other kits but without the diameters it's a non starter so let's hope straitline reply. I've found the bushing manufacturer Igus bushings.
Posted : 22/04/2019 8:02 pm
Used Igus bushings in Time pedals ,expensive for 2 . Bought a pack of 10, they are set up for selling hundreds or thousands.
Posted : 23/04/2019 8:54 pm
