Peak District query...
[Closed] Peak District query - shortcut to Stanage Edge
9 Users
Has anyone ever ridden the concessionary footpath (orange dotted line on OS map) that runs below Redmires reservoirs, from Fulwood Lane to the bottom of the byway that goes up to Stanedge Pole from SW corner of Redmires? I'm fully aware of the legalities of it, just wondering if it's actually rideable or a mudbath?
Looks like a good shortcut to avoid all that boring road round the top of Redmires when heading to Stanage from Sheffield.
Cheers for any assistance.
Posted : 12/12/2013 12:00 pm
Yes perfectly rideable, not often anyone on it so not usually a problem...... Apart from it being a footpath.
Posted : 12/12/2013 12:34 pm
Rode it a few years ago, and was rideable but not very interesting and a bit of a mudbath - you're not missing anything by going on the road.
Posted : 12/12/2013 1:21 pm
the first bit off fulwood head lane is through a farmers yard with a hugh pile of rotting cow crap that leaks a nasty liquid all over the path. This invariably ends up all over your bike. Apart from that not a bad path.
there is a steep rutted grass downhill with a wooden style at the bottom, not easy to stop in the wet, so take care if doing it at night
Posted : 12/12/2013 1:41 pm
Even harder in snow !
The bit below that, a tight singletrack through the trees, is quite good but often frequented by walkers - a mate got a right b*llocking there once, and has avoided it ever since !
Posted : 12/12/2013 4:21 pm
Some bloke on UKClimbing was bragging about pushing a MTBer into Redmires Conduit a while back. So, yes, you may encounter some interesting walkers. 😀
Posted : 12/12/2013 4:26 pm
This is a different trail I think? OP is talking about the one that goes across Rud Hill and White Stones. not the one that goes through Redmires Plantation -past the house with the Cadillac parked up?
The OPs one I think I've walked and is a bit of a mudfest.
Posted : 12/12/2013 4:35 pm
This path http://www.streetmap.co.uk/map.srf?x=427052&y=384546&z=115&sv=427052,384546&st=4&ar=y&mapp=map.srf&searchp=ids.srf&dn=523&ax=427052&ay=384546&lm=0 is a quagmire on the top in summer.
There is however another footpath that starts here and ends in the same place (bottom of byway) http://www.streetmap.co.uk/map.srf?x=427032&y=385489&z=115&sv=427032,385489&st=4&ar=y&mapp=map.srf&searchp=ids.srf&dn=523&ax=427032&ay=385489&lm=0 and skirts round the reservoirs that is OK. It si s bit slidey in places and is mostly OK. The worst bits have recently been flagged so is probably ok.
Posted : 12/12/2013 4:37 pm
Not even walked the Rud Hill/White Stones track, but yep can believe it would be a quagmire
Been meaning to do the one around the reservoir for a few years now, but that would definitely be one for dry summer evening IMHO
Posted : 12/12/2013 4:51 pm
Yep I was referring to the Rud Hill/ White Stones path. To be avoided then...?
Posted : 12/12/2013 5:45 pm
I did the second of these last night and it was fine. As someone has mentioned what was the boggy bit has now been flagged. The only muddy bit was the last hundred yards through the cow poo as you rejoined the road.
Posted : 12/12/2013 8:55 pm
