Any idea what size the bearings are and where I can get replacements from?
Thanks mocha
Hope raised and then dashed...
I think they are the right ones, but they only have one in stock 🙁
Measure them up and find out most bearing suppliers are able to supply them, and usually far cheaper than the replacement costs normally quoted. If they are made by Enduro any shop dealing with Extra Uk will be able to order them as Extra are the UK distributor for Enduro bearings.
Assuming the pic is correct (which it likely is due to the sizes), it says 6902, which is a pretty standard size.
Thanks for everyones help. Sorted!
