First ride on new bonty xdx and got a 5 mm tear in the middle of the tread. Can u patch em and what/ where from?
Goo everywhere 🙁
Ta
Will
yip, just done one for a mate
velox patch kit from justridingalong.co.uk
works a treat and a damn site cheaper than new rubber
here you go
[url] http://www.justridingalong.co.uk/shop.php?product=82 [/url]
Used panaracer kit, basically a needle and thread , then velox kit to seal it up.
Then bought a new tyre soon after as I wasn`t convinced.
HTH
The patch on my High roller has been sound for over a year now including a week or so in rocky Spain.
I've found the needle and sticky thread works well on rips in the centre of the tread. Not in the sidewall though.
+1 for chucky or the weldtite kit - I've had a repair in a nobby nic for over a year and it's fine! Much cheaper than a new tyre!
I mended a couple at the weekend. I used Stormsure neoprene wetsuit glue. I cleaned the inside of the tyre and just poured a blob of this stuff over the area (about a 1 inch diameter circle) and poked it about to make sure the glue had gone right through the hole.
I left it for 24 hours to cure and the repair is as strong and flexible as the original.
