Parts swap. Crank s...
[Closed] Parts swap. Crank spindle too short?
4 Users
Swapped deore cranks onto new bike, spindle too short. It's quite an old crankset but in any case does a new BB or even a new crankset need purchased?
Posted : 04/08/2017 5:38 am
If the new frame is 73mm wide instead of 68mm you only need to add one spacer to the driveside cup (instead of the 2 drive, 1 non-drive you had before).
Posted : 04/08/2017 6:15 am
Is it a DH bike with a 83mm BB shell?
Posted : 04/08/2017 8:07 am
Let's not forget fatbikes...
Posted : 04/08/2017 8:18 am
It's a 2017 Marin Nail Trail 9 and I can't find the spec anywhere that tells me the current BB spec so I am a bit confused
Tinypic isn't working.... I'll probably just take it down the LBS. Things with spacers confuse me.
Posted : 04/08/2017 12:11 pm
Too late for an edit, here....
Posted : 04/08/2017 12:32 pm
^pic not working.
Measure the width of the BB shell on each bike (don't include any spacers in the measurement).
A ruler will be plenty accurate:
Posted : 04/08/2017 5:15 pm
