My stand is missing two of its adjusters. Could someone with a park Ts2(.2,.4 etc) please check the length and thread size of the caliper and caliper arm adjusters. I've been told M10 but an M10 did not seem to fit.
Don't have mine to hand to measure, but thought I'd say that you can get most replacement parts for the stands and usually reasonably priced - e.g. arm adjuster
Given that Park Tool are American it’s quite likely that it’s an imperial thread. Possibly 3/8-16 UNC.
Yeah I can get the parts but some need to be ordered from the US which takes a good few weeks.
I think imperial is a good shout, the only imperial bolts I have are seatbelt mounts. Will try one of those as it's about the right size.
Well seat belt mount bolt is too big, hopefully neighbour has a 3/8-16 UNC to try.
On my 2.2, it measures ~9.3mm outside thread diameter.
btw, Park Tool have always been really helpful whenever I've emailed them.
Perfect, thank you.
Your LBS may be able to order spare parts from Madison once you have part no info from Park.
They could. I have the part numbers and have been in contact with Madison. 2 bits need to come from the US which is about 6 weeks delivery. I'd like to use the stand in the meantime.
Edit park tool publish all the part numbers which makes things easier.
