Pacenti CL 25 rims ...
[Closed] Pacenti CL 25 rims with road tyres - will it work?
3 Users
Will it work, or will I die a horrible death as the tyre explodes off the rim? Would be running 25 - 28mm at around 90psi. Can't find any info on max pressures.
ta
Posted : 16/09/2015 2:58 pm
Been doing just that for 18 months. Either 25mm Michelin Pro 4 SC's at 100psi or Challenge Strada Bianca's in 30mm at 80psi. Emailed the Pacenti importers about max pressures and the reply was , ask your tyre supplier about their pressure as the rims are not a worry.
Lighter than the SL's but probably not as aero. Build up nicely I am told. Only done about 4000 miles on mine so can't comment on life.
Posted : 16/09/2015 4:12 pm
good news...ta
Posted : 16/09/2015 5:09 pm
What build do you have and any idea of weight? I was looking at the superstar ones on sale at the mo and was quoted 1840g, which seems a touch high given the rims are 430g each and the switch hubs are 470 for both.
May consider building them up myself as by my calculations a pair of novotecs with dt race spokes would be around 300 g lighter.
Having said that, aren't SS hubs just rebadged novatecs, in which case they are using some very heavy spokes..
Posted : 16/09/2015 5:38 pm
No idea but various 28mm have worked fine for me on crest/arch which are 21 internal
Posted : 16/09/2015 6:01 pm
No idea on weight? Mine are on old Hope xc hubs. 32 DT spokes. Proper Campag Qr's. Only snag is that they are black.
Posted : 16/09/2015 6:18 pm
