Pace RC39 - Fork Se...
[Closed] Pace RC39 - Fork Service help
5 Users
Have given my RC39's a full service, new seals, oil etc, but have a question. How much damping oil should be in the damping leg? I have put 30cc of 5wt oil in, but the lockout doesn't work even though I have primed it. Should I have put more or less oil in?
Thanks all
Posted : 09/01/2010 10:37 am
Confirmed by the pace website, it is 100ml of 10wt oil in the damper unit (i use fully sythetic motorcycle fork oil), and then just 5cc of lubricating oil in the bottom of each leg (again, i use the 10wt fork oil, using a small syringe to inject it through the bolt hole before replacing the bolts in the bottom of the legs).
Hope that helps.
Pete
Posted : 09/01/2010 10:52 am
I think it's 90ml unless the legs are perfectly dry
I'll have to dig the manual out to be 100% on that though
Posted : 09/01/2010 10:56 am
Thanks, I couldn't find it on the Pace website anywhere.
I have found 5cc in the top of the air chamber also helps to keep the forks smooth
Posted : 09/01/2010 10:57 am
Uplink is correct. Deduct 10% fluid unless perfectly dry.
Posted : 09/01/2010 11:48 am
Can anyone help please
How do you replace the damper oil I cannot get my damper assembly apart.
Is there a web link I have never been able to find one
Ta in advance
Posted : 09/01/2010 7:37 pm
IIRC you don't take the damper apart you just cycle it to get as much oil out a possible and then refill. The 90ml referred to above is because you can't get it all out.
Posted : 09/01/2010 7:41 pm
Ok so how do you get the oil out in the first place??
Posted : 09/01/2010 7:46 pm
Called my bluff there...
I'm thinking about RC36s (hollowform) and with those there is a big circlip at the top of each leg at the crown - take those out and you can drop the innards out.
Presumably you've looked at the manual [url= http://www.pacecycles.com/downloads/RC31_RC39.pdf ]here[/url]
Posted : 09/01/2010 8:14 pm
Yes I have alas there is no infomation there
Posted : 09/01/2010 8:32 pm
Might be worth looking at the other model manuals too, as the basic construction for all Pace forks is the same.
Posted : 09/01/2010 9:20 pm
On mine I had to take the circlip out of the bottom of the stanchion, then unscrew the blue rebound adjuster for about 5 minutes until it is fully disengaged. Then pull the damping rod and it all came apart. Assembly is a reversal.
Posted : 10/01/2010 8:38 am
