Hi,
Finally getting round to sorting these forks. Does anyone have a guide to a full upper and lower service? Similar to rock shox with lower leg bolts?
Also, can you swap a new cable into the lockout or is it a whole unit replacement?
Thanks
Chris
http://www.pacecycles.com/manuals-exploded-diagrams/
Might be of some help
You can swap the cable but need to unsolder it from a brass fitment that fastens into the compression damper - and resolder the new one. You can take it off completely too and the forks work fine IIRC.
Edit: oil change info used to be on the Pace website. Think it was 7.5 weight but not sure. Legs come apart with circlips at the bottom of the legs. Take them off really carefully and you can reuse but not recommended by Pace...
Thanks goldigger, I'd found that but the manual there is more just about regular maintenance and swapping the spring side.
Thanks anyway
Thanks Hamish. Stupid question but assume I need more than a soldering iron? Is it blowtorch stuff?
Good point, I can't remember how I did it. Think I used a plumbing torch but I didn't refit a new cable. If you are you need to check nipple at the lever as I don't think it's a standard one.
