I have a Kona P2 in 29er flavour, what is the largest tyre it'll accept?
Assuming it won't be 29*3", what reasonably priced fork for a plus sized frontage?
Ta.
P2 triple butted is pretty full with a 2.3 purgatory. Might take a 2.5 tops imo.
Thought as much. When it was last in use it had a 2.25 with plenty, but not bags of room IIRC.
Any recommendations for a none too expensive 29+ fork anyone?
2.3 purg is a pretty nobbly tire. Had plenty room with a 2.4 racing Ralph but a 2.3 purg was tight
Salsa Cromoto takes 3 inches, Surly Krampus and KM forks too. Just check the A2C.
But better go for Salsa, its much nicer.
https://m.aliexpress.com/s/item/32450736615.html#autostay
These are pretty darned good, and much lighter than a steel fork.
Exotic etc if long enough
Just looked at the Salsa's- 3kg, is that right?!
Like the look of those Chinese ones, shame the £ is so weak now.
Edit: eXotic fine with plus tyres then?
breadcrumb - Member
Where did you find such weight? It is listed on Salsa website with 1080g.
[url= http://salsacycles.com/components/category/forks/cromoto_grande_29er ]Cromoto Grande[/url]
It never bothered me, so never tried to verify it.
Might be CF forks is lighter, but I prefer how the steel feels 🙂
Cheers!
I.
3kg? For frameset maybe 🙂 forks are ~1100g
Easily
CtBM site for the 3kg weight. I thought it seemed a bit weighty! Must be a 5mm wall!
Thanks for the input though everyone, much appreciated.
Singular swift fork takes a 3 inch tyre, is more comfortable than a Salsa, and handles better with the 55mm offset.
Good call on the swift fork. Not a bad price either.
Another vote for the Singular fork!
Niner Steel rigid easily runs one.
I now have Chronicle sitting on a 40mm (internal rim).
I've two rigid forks sitting in the garage, my Project 2 and On One Chromo fork.
The On One is 30mm shorter than the Project 2 and has less trail.
The Chronicle fits in both, a good 6-7mm clearance either side in the On Ones. Only about 3mm per side with the Konas.
On One Chromo-
[URL= http://i14.photobucket.com/albums/a333/boff1979/mtb/IMG_20170505_183309720_HDR.jp g" target="_blank">
http://i14.photobucket.com/albums/a333/boff1979/mtb/IMG_20170505_183309720_HDR.jp g"/> [/IMG][/URL]
Kona P2-
[URL= http://i14.photobucket.com/albums/a333/boff1979/mtb/IMG_20170505_183451612.jp g" target="_blank">
http://i14.photobucket.com/albums/a333/boff1979/mtb/IMG_20170505_183451612.jp g"/> [/IMG][/URL]
I fear it's a little too tight on the P2s.
