Overbiked ? Underbi...
[Closed] Overbiked ? Underbiked ?
33 Users
Im looking at buying my first full suss bike next summer. The bikes that the LBS carry are usually 120-130mm and 150+mm of travel.
My question is should i start off buying a short travel bike and then having to upgrade after 1-2 years or should i just be overbikeed from the start?
Posted : 17/11/2017 10:34 pm
Shorter travel every time. Unless you live in the alps or somewhere.
Posted : 17/11/2017 10:40 pm
What are you planning on riding?
 leth
What makes you think 120mm will be underbiked?
Posted : 17/11/2017 10:41 pm
To be honest i still don't know 100% what most of my riding will consist of becuse this summer i only had time to ride the flow trails.
Posted : 17/11/2017 10:46 pm
Wandering free?
Posted : 17/11/2017 10:51 pm
Because i feel like somtimes i need at least 30-40mm+ of travel , but now that i think about am i just imagining this need for more travel ? ❓
Posted : 17/11/2017 10:52 pm
Summer i only had time to ride the flow trails
Such as....
Posted : 17/11/2017 10:55 pm
I’ve just gone from a 140mm Cannondale Trigger to a Whyte T130rs with you guessed it...130mm travel.
Far better, more capable and confidence-inspiring bike. It’s not the travel necessarily...more how it feels.
I could do talking bollux though 😉
Wombling free
TBH it doesn't really matter all that much- the actual bike makes a huge difference. my Remedy 29 is a monster truck, 150mm of travel and clown wheels- but it's still great at red routes and simple stuff. And you can get shorter travel bikes that can rip up more challenging trails. These days there are loads of bikes to choose from that can do both extremely well.
Posted : 17/11/2017 11:28 pm
I'd go for 120-130mm, unless you have a specific use for the 150mm e.g. racing enduros or uplift days.
Although I imagine either would be fine for most types of riding.
Posted : 18/11/2017 2:01 am
Geometry > travel
Posted : 18/11/2017 3:36 am
 poah
It isn't just travel that makes a bike.I suggest you try a few.
Posted : 18/11/2017 3:43 am
Upgrade=Moar travel?
Posted : 18/11/2017 8:00 am
depends where you ride, and which bike you're considering
Posted : 18/11/2017 8:03 am
Depends on your riding really - however 90%+ of the people I ride with all have 150mm+ and ride them everytwhere. Those with shorter travel bikes (apart from the whippets), generally end up with bigger bikes eventually.
They are used for Alps, Peak, Derbyshire Dales, Trail Centres (mostly BPW) and all day epics. I've never heard thr phrase overbiked uttered once, apart from on here. That said, half the group ride HT's through winter.
Don't listen to the socialists on here - if they think you have too much suspension, they'll insist you give some away... 😉
Posted : 18/11/2017 8:06 am
I agree that it's not all about the amount of travel but the bike as a whole package. Some short travel bikes are really capable and some long travel bikes pedal really well. Get demoing some bikes to see what you like. I went with a short travel but very capable bike in the end.
Posted : 18/11/2017 9:01 am
As above its the whole package, don't let more travel unnecessarily sway you.
Also...getting a long travel bike and running it as a soda may give you some mental comforting, but does make jumping (a reason I hear a lot for a bigger bike) a lot harder and more uncontrollable. Big soggy bike, particularly in the forks is way worse on steep too.
If you want more for comfort, bear in mind if you're feeling beat Up, you're most probably riding harder for longer, of course youre going to feel beat up.
Posted : 18/11/2017 9:47 am
I’ve been up and down travel over the years and have come to the conclusion that for all the riding I do a 100mm 29er has enough travel.
Posted : 18/11/2017 11:24 am
 igm
I ride a rigid fat bike and a 160mm travel bike in the same trails.
Neither is better - they’re just different.
I can ride lines on the far bike the full suss struggles with (or at least I struggle with on it) and vice versa.
There are good bikes and bad bikes, but travel is rarely a determining factor on that.
Posted : 18/11/2017 11:32 am
I always think your better off using say 90% of your 130mm travel most of the time than lugging round 160mm of travel that you only fully utilise 10% of the time. So are you [i]really[/i] a 90%er of 160mm? But I ride a 120mm hard tail...
Posted : 18/11/2017 1:12 pm
The reasons not to have a bigger travel bike:
1) Some big travel bikes are hard work on smoother trails
2) For any given spec, a longer travel bike will be heavier
3) For any given spec,a longer travel bike will (probably) be more expensive
If you can [b]afford[/b] it, and you are not actually racing XC (where weight really matters), then a modern 150mm bike is light, fun and capable.
Posted : 18/11/2017 2:00 pm
qwerty - Member
Sure, but these days the weight penalty you're lugging around is often small between a "trailbike" and an "enduro bike"- you're likely to end up with something like Pikes, a Reverb, 471s, some Minions, wide bars and strong brakes... Everything on my 150mm 29er would make total sense on a 120mm 29er, as long as I was riding it on similar stuff
Posted : 18/11/2017 2:02 pm
NW - I wasn't thinking of the weight so much, more just getting the most use out of the given travel. But I agree, probably not a huge difference in weight.
Posted : 18/11/2017 2:07 pm
underbiked... overbiked...
wombling free... the wombles of wimbledon common are weeeeee...
Posted : 18/11/2017 2:46 pm
Gwurk the comedy womble- picking up other people's jokes and recycling them 😆
Posted : 18/11/2017 2:48 pm
You didn't think I actually read the thread did you?
Posted : 18/11/2017 2:59 pm
Not digging today? that mean you're going riding tomorrow?
Whereabouts?
Posted : 18/11/2017 3:01 pm
Probably- I thought maybe thornielee. Or maybe I'll get Chris out of hibernation
Posted : 18/11/2017 5:06 pm
Overbiked = fat. Underbiked = lacking in skilz.
Hth.
Proper answer though as above there's a lot more to a bike than the travel. Ride a few and see. there isn't much point carrying around travel you won't use and a well set up 130 or 120mm should be fine even for the odd alpine trip. But a decent 150mm bike shouldn't be that slow uphill these days either.
Posted : 18/11/2017 7:35 pm
Thornie sounds like the right place to wake a fella up.
I love that place. CBA mountainbiking these days either.
To answer the OP
if you want a longer travel bike that'd still rides well in less than gnarly terrain look for one with a very progressive leverage curve.
Posted : 18/11/2017 7:59 pm
I rode a friend's Capra for some of a less than gnarly ride a couple of weeks ago. 170mm front, 165mm rear travel - which I really noticed when I sat on it and it sagged what seemed like miles. But it felt absolutely fine once riding, far from a pointlessly soggy sofa of a long travel bike, handling well and climbing brilliantly. And it has one of the most progressive leverage curves of any bike on the market. I think YT might sell quite a few...
Posted : 19/11/2017 8:58 am
Are you a bit heavier than your friend or does he have it set up with too much sag? or are you just not used to long travel bikes?
That progressiveness is what makes the Capra sit so nicely at the sag point giving you a nice firm platform to push from. Run with the same % of sag and compression my Capra jumps and pumps better than my 120mm slopstyle bike.
I run the slope bike with way less sag, 50psi tyres and in the middle "pedal" compression setting rather than full open for jumps/berms.
Despite climing a minimum of 3000ft on every ride I never move the Capra's compression lever from full open. infact. the lever's taped in that position.
Forks these days (Lyriks especially) are already progressive enough. Thing is most folk run too much sag and then stick bits of plastic in to stop them bottoming out. ramping up the progression ruins that nice firm sag point. Run less sag. no plastic and they will give you a firmer ride same as the back end of that Capra. Yeah you lose a tiny bit of small bump suppleness but c'mon. if you're riding a 170mm fork surely you're hitting stuff fast/hard enough not to mind that.
Posted : 19/11/2017 2:58 pm
There's a couple of things i quite like about longer travel bikes:
1) with the massive assumption you've got decent spec parts (ie pikes etc) then i find due to the extra travel, the set up is actually less critical. you can run with the settings in the "middle" so to speak and pretty much the fork just works
2) You can run deliberately "soft" ie lots of sag, and get a nice comfy ride when you're just pootling around
Posted : 19/11/2017 3:08 pm
As with most of your *skills* advice Max
Posted : 19/11/2017 3:12 pm
We're the same weight but from how much it sagged I think he's running a bit more % sag than I do on my Spitfire (about 28%) but not too much - and I'm not used to long travel bikes, my "big" bike is only 140mm at the back and I've been solely on my hardtail recently.
But as you said, that's what I noticed - once it's settled into the sag it firms up really well - from the amount it squished down I thought it would pedal and pump badly but it was great at both. Light too. Only negatives I felt were too much seat tube length and too slack seat tube angle (at pedalling height) but only marginally.
Posted : 19/11/2017 4:24 pm
was it a Large?
I'm on Medium. Despite being 5'11" and it has a little over 210mm of seatpost exposed (Rails to collar) at climbing height
I'm running 18-20% front 23-25% rear sag. Rarely ever use the last 10mm on the fork (but like all my forks that way). do on the shock.
I ride hardtails and BMX more than I ride mine.
Posted : 19/11/2017 4:53 pm
Will make it very simple for you...
More downhill gnaaaarrrrrrrrr or you walk uphill. Then long travel.
Downs / ups / flats / uk riding mainly. Then shorter travel.
Don't over think it
Job done. N
Posted : 19/11/2017 5:01 pm
gwurk
Care to enlighten rather than just post stupid memes?
Here's the thing, if you're riding say a 100mm fork, if you have it too firm you don't use any of the travel, and too soft and you're sitting on the bump stops, ime, this means you need to get the correct fork pressure and chamber volume within a pretty small range. But a 150mm fork, well, that extra 2" doesn't sound like much (phnarr phnarr) but againm ime, makes all the difference. Now, the difference in preload and volume makes much less difference, as the fork simply has further to move before it hits either end stop. And that also makes sag less critical, as "somewhere in the lower 3rd of the travel" is simply a bigger range!
Sure you'll disagree but hey, that's my experience from running bikes from 80mm to 210mm travel!
(btw, i'm not saying a poorely set up fork IS a good idea, but lets be honest here, most of the time we just want to get out and ride our bikes, not phaff around the in car park with a shock pump because we're carrying a bit more water today or because it's cold etc, so a bigger operating window is a good thing i think)
Posted : 19/11/2017 5:07 pm
*sigh*
Running your fork "deliberately soft". ie. with too much sag ie. For "comfort" while pootilng around is going to equate to blowing through too much travel the first time you hit a transition or infact make any manouver where you are pushing through your bars or riding your bike properly. An overly soft fork is also way more likely to spit you on your chin in a corner.
This shouldn't be enlightening. it's the fundamentals of how suspension works.
You may well have experience. Experience is not the same as expertise or even knowledge or understanding. Not understanding the fundamentals and having no real knowledge of whatever you've experienced means every time you share advice. You are in fact more likely than not giving out poor advice.
The "stupid" meme summed up the above very well. I didn't think it needed explaining. But then i wouldn't think someone with an £800 bicycle fork wouldn't understand how it worked either.
Posted : 19/11/2017 5:50 pm
@jonas - test ride as many as you can in your price range, ideally on similar terrain to what you want to ride. Buy the one that makes you grin the most.
I rode a 100mm hardtail for years. Loved it. Took it to the Alps. Loved it. Got a too-good-to-pass-up deal on a 120mm full sus. Was a bit "meh" - sold it when I realised I was always choosing to take the hardtail out. Persuaded to demo a Banshee Spitfire (160 front, 140 rear), way more travel than I thought I'd ever need. Loved it. Demo'd loads of other bikes to try to persuade myself not to spend all that cash. Came back to the Spitfire - now I ride it everywhere and never fail to return from a ride grinning.
Posted : 19/11/2017 7:04 pm
gwurk - Member
er so what?
Did i say i'd be running in "comfort" settings when smashing it down a double black downhill run? I'm talking about being able to soften off your fork for when you want comfort over impact absorbance. In the UK, despite what you see on the gnarr-fest that is you-tube, a lot of people, me included, ride a lot of miles on stuff best described as "pretty tame".
For example the other day i rode 25 miles along the Ridgeway for example, and at no point did i huck off anything, or need to push through the bars, what with it been a basically flat gravel and clay track! But, it's cut up to heck by horses and when that dries, it dries into a horrible jarring washboard type of surface, and by running lots of sag, i could just roll straight through it all whilst sat down an pedaling (which is what you'll be doing if you ride somewhere similar) On a short travel bike that sort of surface can get pretty wearing pretty quickly (i should know, i've raced events over the same routes on my XC race HT, and it beats the crappola out of you!)
Again, no, don't run your fork so it's sat in the bump stops, that NOT i'm saying, i'm saying that a long travel fork can be set up to ride in different ways by changing the base pressure and volume spacers to suit different terrains. A short travel fork, well, not so much, because as you point out, if you soften that off too much you will be into the bump stops more often
Surely that's not too hard to understand is it?
(or are you too busy just being deliberately obstreperous?? 😆 )
Posted : 19/11/2017 7:24 pm
I went from a 120mm 26" Spesh Camber to a 160mm Nukeproof Mega 275. I was riding three times a week back then and fitter than I am currently. Unsurprisingly, the Spesh is faster on the way up and the Nuke faster on the way down. The Nuke fits me better though and I like riding it more, so the Spesh has been handed down to my son. The gap on the way up is closing as I get my fitness up to where it was when I had the Spesh.
Is 160mm more than I need? Probably, but who cares? I like it.
Posted : 19/11/2017 7:30 pm
Softening a long travel bike's springrates for 25 miles of bridleway riding?
Really?
erm... ok. :/
Deliberately obstreperous?
No. far from it. You asked me to enlightened you regarding the poor advice you give. I took the time to explain something very basic to you. You can't grasp it. Fair enough. I tried. No skin off my nose. I'll leave you to enjoy your badly set up bike.
now back to these guys...
Posted : 19/11/2017 8:00 pm
Get a room you two !
Thing is a lot of folk have one bike. Locally to me and those I get to ride with it seems that most want that bike to do it all and it's descending most enjoy so bikes are mostly 140 - 160mm. And as it's generally the 150-160 bikes that have the slacker fronts that's what most are. No one cares that the bike may weigh a pound more they just want to enjoy the downs. And most modern bikes with that kind of travel climb OK as well. 'Overbiked' for the canal path, yeah but who really cares ? 'Underbiked' for Fort Bill, yeah but do they care ? Nope, just the STW hand wringers.
Posted : 19/11/2017 9:07 pm
It's not long ago that 150mm bikes were winning world cups. If you "need" more than that, you must ride some interesting terrain.
I have just got a 130mm bike (having not ridden much for 10 years) with a lock out, which helps on climbs. When I get round to it, I will increase the oil height in the forks to make them more progressive at the bottom of the travel, but tbh, they are really soft just now, and I rarely use more than 50% of the travel on a dh as my weight is over the back wheel.
Posted : 19/11/2017 9:18 pm
gwurk
Really?
so you run with the same suspension settings for sending it down a WC DH track as you would taking part in a 1000mile marathon event?
Posted : 19/11/2017 9:27 pm
Simple fact is, the longer your fork, the lower spring rate you can run before you hit the bump stops (F=MA and V = FT) for any given deflection.
Posted : 19/11/2017 9:29 pm
Is it bad that my answer would be yes.
I'm doing Afan in the same settings I did the SDW, the same ones I did BPW on
Posted : 19/11/2017 9:31 pm
not at all, it's all personal choice!
for me, i'd run way higher pressures for smashing down a DH run at max chat that i would for a 25 mile pootle along a horse rutted bridleway.
And that's really my original point, the longer your fork, the more window you have for setting up differently even if you chose not too 😉
Posted : 19/11/2017 9:36 pm
It's probably best I leave you to figure it out yourself.
so long as you enjoy the ride!
Posted : 19/11/2017 10:00 pm
Not trolling, but i'd love you to properly explain what i'm missing?
Say you want to change the velocity (v) of an object of mass (m)
As F=MA, and V = FT, a given deltaV can be achieved with either a higher force over a shorter period, or a lower force over a longer period. So, the longer travel you have on your suspension, the softer (lower spring rate) you can run. The end result in the same deltaV but as every force has an equal and opposite fore, a lower force over a longer period is more "comfortable" especially for devices such as pedal and motorbikes where the ultimate ratio of sprung to unsprung mass is characteristically poor.
Posted : 19/11/2017 10:05 pm
Which one of those is a WC DH track?
Posted : 19/11/2017 10:10 pm
Forget the first year Uni mathematics/physics
Let's go back to your stupid 1000mile on a WC DH bike anology...
Would you really want your suspension cycling through all 200mm on the sort of bumps you find on a bridle way?
No.
Just because you payed £800 for 170mm of suspensionz doesn't mean it's appropriate to set it up to be using it all on every ride.
Blowing through travel too easily is not only horrible. it performs poorly, results in an unstable ride and loss of grip.
Posted : 19/11/2017 10:15 pm
gwurk
Forget the first year Uni mathemeatics/physics
Ignoring the fact i have repeatedly said i'm not talking about letting all the air out of your fork, say just moving the sag % about 5 or 10%, ie, if you'd run 25% normally, then 35% sag brings a more comfortable secondary ride frequency without major differences in primary ride frequency (which for something of low mass like an MTB is set more via the damping components (inc. friction) for low velocity damper extensions
Why would it "cycle through it's travel" when there is no inputs from the road surface to force it to do so!
Posted : 19/11/2017 10:22 pm
10% more sag is huge.
imputs aren't just from below the bike
Posted : 19/11/2017 10:29 pm
No matter how retarded it is. If you genuinely enjoy riding bridleways more while being sagged 35% into a 170mm fork keep doing it.
it's your money.
Posted : 19/11/2017 10:31 pm
By the logic in this post everyone should be rolling around on DH bikes as thats all anyone needs. Sag it your if you are on a canal towpath, reduce the sag if you are riding gnar. SICK.
Posted : 19/11/2017 10:39 pm
The shrooms are strong in this thread
Posted : 19/11/2017 10:46 pm
Sorry!
I thought i had missed some critical fact, as i obviously haven't got a clue what i'm talking about, but it turns out that no, i hadn't, or at least if i have, gwurk is for some reason unable to articulate the issue!
(btw, i spent 3 years as a WRC suspension engineer, during which time we won the championship so i can't be that bad at suspension eh..... 😉
Posted : 19/11/2017 10:50 pm
I'm guesing the WRC driver didn't weigh 6x more than their car?
or constantly move from the front to rear and side to side of the car for the duration it's journey to...
Posted : 19/11/2017 11:05 pm
No you aren't, that means you have very little left in reserve for either sending it large or making a mistake.
I'd rather run a 160mm stiffer, than drop down a 130mm bike and run it softer. The former is going to be more playful and safer to ride.
Posted : 19/11/2017 11:23 pm
None, but if i took my bike to the Alps i wouldn't change the settings either.
Posted : 20/11/2017 8:10 am
I dont get the arguemnt between Gwurk and Max, fork settings are personal choice. I have a 160mm Lyrik which I run just over 30% SAG everywhere.
Overbiked or undrbiked, did anyone ever die from being overbiked?
Posted : 20/11/2017 8:57 am
I wouldn't dismiss shorter travel bikes - my Scout is a little hooligan of bike despite only having 125mm of rear wheel travel and being designed to run 33% of sag.
I've had a 160mm travel bike before and it did feel like hard work on the tamer stuff (on the right stuff it was brill though). I ended up going the other way and riding hardtials but have ended up on the Scout and am so far really happy with it.
I tend to run my suspension at 30% sag (my Yari's don't have any tokens in them). Works for me.
Posted : 20/11/2017 1:36 pm
I truly don't know how people can run 30 percent sag on forks with no tokens, especially the shorter travel forks which need more tokens. I'd constantly be running the risk of bottoming out and going OTB with a setup like that. 😕 😯
Posted : 20/11/2017 3:35 pm
They seem to ramp up big time and don't bottom out constantly. With one token in and the Luftkappe they were just too harsh and I wasn't getting enough travel out of them.
Or I'm just not as rad as you... 🙄
Posted : 20/11/2017 8:03 pm
I think it depends on a lot of variables - the air spring curve, the damping curves, your weight and probably most importantly your riding style on the bike. And obviously how fast you're riding and how big you're sending it.
I'll get pretty heavy on the front in the turns, especially flat ones, but as soon as I'm hitting rough stuff I'm loading the bike more through my feet. I don't ride with 30% fork sag because I prefer the firmer feel with a bit less but I've tried it (pre-Luftkappe) and it wasn't disastrous.
Posted : 20/11/2017 8:25 pm
And Yaris are known to ramp up way more than Pikes or Lyriks due to the damper design effectively adding a parallel low volume spring to the main air spring.
Posted : 20/11/2017 8:27 pm
Yup. Tried them with one token and 20% sag and they were unbelievably harsh. On a normal ride I was struggling to use more than 100mm of travel. Without the token and a tad more sag they’re doing a grand job but I will be getting some coil forks in the new year because they’re just nicer.
Posted : 20/11/2017 9:19 pm
