oval rings on a dou...
[Closed] oval rings on a double
6 Users
I've got one bike set up with an oval NW ring and love it. Would like to convert a double on the fat bike to a double but is this possible? Any pointers or suppliers you can recommend?
Posted : 04/02/2016 10:54 pm
Rotor QX2 in a few different BCD...
http://rotorbike.com/products/mtb/versions/qx2_50
Posted : 04/02/2016 11:01 pm
 JoeG
Posted : 04/02/2016 11:42 pm
Ha ha Thanks. I'm old enough to have run biopace on a roadie twenty five years ago!
Posted : 05/02/2016 6:54 am
 lerk
Rotor mtb ovals are about £300 and from what I can see are no longer made...
I too have been looking at the idea.
Best I could think of was to use two NW rings and bin the mech, just having the granny as an emergency option.
Or going ridiculously low on your gearing choice - I have effectively done this on my alfined bike to miss the gear inch chasm between 1st and 2nd, it really doesn't bother me if I spin out on downhill sections.
Something like a 28T oval?
Posted : 05/02/2016 7:06 am
NW won't work with a double.
The NW is designed to keep the chain on, and you'd have no control on the chain aligning with the ring correctly.
Posted : 05/02/2016 7:08 am
Doval do them. Search ebay. You'll probably need to buy from Asia and the ovality (?) is quite mild but otherwise they are fine.
Posted : 05/02/2016 7:19 am
Thanks very much I'll check that out. Hadn't yet priced up the Rotor option but thought it might sting.
Or might need to look at expander and go one-ten nw oval but currently like the range of the double on the fat bike
Posted : 05/02/2016 10:05 pm
