Fancy trying them and as my rings need replacing anyway, now seems as good a time as any. Seen the AbsoluteBlack ones, any others to look at that are easily available? Need to be compact or semi-compact for a Ultegra 6800 chain set.
Thanks all.
Can you get aftermarket rings to fit Ultegra? I thought the bolt spacing was proprietary...
Edit: apparently you can, should have googled before I posted. Good to know!
AbsoluteBlack say they fit, they even have spacers to make it all look like it was designed that way.
I run an absolute black 36t oval on my compact ultegra. Fits perfectly and(I think) works really well.
Cheeky bump.
I use Rotor Q Rings on the road, have done for 10 years. Love them.
Froome uses Osymetric chainrings available on Wiggle.
