OS Maps on Garmin 8...
[Closed] OS Maps on Garmin 800 probs
5 Users
Following all the instructions as already posted but can't seem to get file from SD card onto unit ? The problem seems to start from when I download the gmapsupp.zip file I don't seen to be able to then open it and extract what's in there, when I try it comes up as a PDF file that says is unsupported, am I making some kinda schoolboy error here ?
Posted : 06/01/2014 1:38 pm
Where did you get the file from? I take it you mean OSM rather than OS?
Posted : 06/01/2014 1:41 pm
Yeah sorry got it from here garmin.openstreetmap.nl
Posted : 06/01/2014 1:44 pm
should just unzip the .zip file and there'll be a gmapsupp.img file inside
on older garmins, you just copy it on the SD card (or internal memory, I assume, if no SD card slot?) in to a folder named Garmin
on newer ones, they may be able to understand more than one map file? (not sure).
Posted : 06/01/2014 1:47 pm
As above, should be pretty simple. Is there something up with your computer that is preventing it from handling zips properly? Can you right click on the zip and choose to extract it, or open it manually from WinZIP or something?
Posted : 06/01/2014 1:53 pm
Trying right click extract now as it just keeps come up as an adobe file when I try 'open' & then abode says it can't open it
Posted : 06/01/2014 2:07 pm
Sounds like something's messed up. Can you unzip other zip files on your computer OK?
If not download the free trial of WinZIP (or any other free zip utility) and try using that to unzip the file.
If you can then maybe the file didn't download properly, so you could try again.
Posted : 06/01/2014 2:17 pm
Trying with a free zip utility now. If all else fails can I do this on somebody else's PC just to upload the maps on the device
Posted : 06/01/2014 2:27 pm
Yes that would work.
Posted : 06/01/2014 2:41 pm
Cool gonna do it that way as nothing seems to be working here even winzip ?
Posted : 06/01/2014 2:50 pm
I guess you could try re-downloading the map from somewhere else and see if that works? This is the guide I followed [url= http://www.dcrainmaker.com/2013/05/download-garmin-705800810.html ]http://www.dcrainmaker.com/2013/05/download-garmin-705800810.html[/url]
Posted : 06/01/2014 2:57 pm
Yeah they were the instructions I was following from the recent thread, I think my PC is ****ed nowt working every time I try to extract the zip it comes out as a PDF that Adobe reader then say can't open, I even uninstalled AR from the PC to see what would happen then the file was converted to some sort of image disc ?
Gonna try neighbours computer see what happens then
Posted : 06/01/2014 6:03 pm
is the zipped file a ".img" file, thats the format you need? If you have the unzipped .img file on the SD card the unit reads it automatically, you don't need to move/install it onto the unit itself.
Posted : 06/01/2014 6:17 pm
Yep, as above, sounds like you're nearly there! Just copy the IMG file onto the GARMIN folder either on the device itself or the SD card then reboot the Garmin.
Posted : 06/01/2014 7:04 pm
Sorted my neighbour did it on his laptop for me, did exactly as I did but some reason mine just wouldn't extract the fIMG file to put on SD card ?
Cheers everybody
Posted : 06/01/2014 8:52 pm
If anyone's interested, I'm creating Garmin img files of England / Wales / Scotland (individually and probably combined) with OS 50k look/feel. It's using OpenStreetMap data so nice and detailed. I'll add contours also.
If there's interest then I'll put the file(s) up on the web for STW download.
Posted : 07/01/2014 11:27 am
Cool that could be interesting. What software are you using to edit the maps?
Posted : 08/01/2014 9:46 am
