Orthotics and spd s...
[Closed] Orthotics and spd shoes
3 Users
Had a cleat assessment a while ago and it turned out my knees were massively offline compared to my ankles, to the extent that I was advised to go and see a podiatrist. Turns out I have a forefoot varus angle of 4degrees which was causing my knees to move inward under pressure. He stuck a wedge underneath my insoles which has straightened out the alignment. The problem is because it's raised my forefoot a bit my heel feels loose in the shoes. I think it's partly because spd shoes are narrow and so there isn't much space. I'm getting a bit of knee pain that may or may not be related.
Anyone else have issues with forefoot angle and alignment? Any recommended orthotics that fit well in spd shoes?
Posted : 13/08/2015 4:40 pm
What about heat molded insoles that you warm up in the oven then put in your shoes.. I have several pairs of soletec ones but specialized make them too.
Depends if they offer enough support to correct your issue
Posted : 13/08/2015 4:51 pm
 Joe
I would go back to the podiatrist or speak to a podiatrist who does lots of cycling stuff. I've had similar issues.
Posted : 13/08/2015 4:57 pm
