Orange Stage Evo , ...
Orange Stage Evo , any thoughts from owners?
40 Users
24 Reactions
Currently on a HT and regularly cycle in clay/mud during winter. When I tried out mates FS I remembered how nice some squish is. Anybody got some long term thoughts?
I have had a Single Pivot SC super light some time ago and like the mud clearance and simplicity. 5'11" so it's a large or XL?
Posted : 29/07/2022 9:51 am
Personally, I wouldn't let mud clearance / number of bearings force me towards a certain bike. I had a single pivot Starling Murmur. It really wasn't any more or less hassle than any other bike.
Yes bearing change was quick and easy, but still had to be done at similar intervals.
What kind of riding do you do and what's the budget? At 5'11'' you're likely to be large, but you may be able to up or downsize depending on bike.
Posted : 29/07/2022 9:56 am
99% forests fields and woods with wheels on ground. Covering distance up and down, with very mild lumpy bits and logs and whatnot.
Posted : 29/07/2022 10:02 am
Defo large as its fairly stretched out as is teh fashion- should have bought mine that was advertised a few weeks ago as I ended up giving it away virtually...
Im just over 6ft with a 32 inch leg and definitely wouldnt have wanted it bigger
Great bikes by the way just dont seem to have much profile for some reason so if you go second hand you may be able to get a good deal if you are patient
Posted : 29/07/2022 10:03 am
zerocool reacted
Posted elsewhere but some off the top of my head...
Had Oranges before including a 2018 Stage 4 which so very close to being right, but the geo wasnt quite caught up then and it was limited in really high speed stuff by the small rear shock (Fox DPS).
Had other stuff in between including a Hightower but went from SC + Hardtail to a Stage Evo in November - its my only MTB now.
+ The paint finish, graphics and quality of the 2022 is steps nicer than the 2018.
+ The updated modern geo means that where I used to ride a large, I now ride a medium, and can run a proper decent dopper post (was limited to 100, now ride 150mm drop).
+ The old one had a Fox DPS, an XC shock. The new one has the 2022 Fox Float X, which is 5mm longer stroke, much bigger oil capacity, big soft bottom out bumper etc.
+ Its light weight (comparable to lots of carbon equivalents)
+ Now got bottle cage mounts
- They are on the downtube
- Its not cheap
- Its very hard to get a test ride or sit on one
Its not the plushest or most cosseting - thats not the point. Its 'less is more' and that might or might nor work for you. Its really, really fast when you stand up and sprint, it feels lively, and you can always tell whats happening under your feet.
Its a good bike to come to from a hardtail for those reaons too, it will give you lots of benefits without feeling too leaden and dull which a more competent, plusher or longer travel bike can do.
Mud clearance is also brilliant, that used to frustrat me with many other bikes, Oranges stay cleaner for longer and dont clog up. Makes a difference in Winter.
Less is more.
Posted : 29/07/2022 10:26 am
Echo Snotrag there. Mine is really likeable, feels like a step up from a hard tail without being too cosseting. I came from a Cotic Flaremax and this is more me and certainly lighter. I’m 5’10” and went for a large which is perfect.
No test ride, just ordered from Dales Bike Centre who I trust for advice.
Posted : 29/07/2022 12:06 pm
I have the Stage 4 (Snotrag's old frame) with an angleset, and if I had to replace it the Stage Evo would be top of my list.
Spot-on, much more lively and engaging than other short-travel shred sleds I've owned (Smuggler, process 111).
Only downside (as with most FS Oranges) is no room for a bottle in the frame.
Posted : 29/07/2022 1:38 pm
I posted something last week about a new bike and decided after owning 2 full sus Oranges long term now that what I wanted was a third. They match my ability to set aside time for maintenance absolutely perfectly. Just picked up my new Five Evo last night...
If you're interested, I know someone who is going to be selling a 2019 Stage 5 (I think its a Factory) in large... Not quite as gnar as the Evos in geometry but a hell of a lot less to buy. I was tempted but at 5'8" I would be been extremely borderline in terms of sizing...
Posted : 29/07/2022 1:47 pm
I have the five evo’s predecessor, the four.
Cracking bike and I can’t see me ever getting rid. I’m 5”11 and riding a Large.
I strapped a fidlock to the underside of the top tube to overcome the lack of bottle bosses. Not ideal, but it works ok.
Posted : 29/07/2022 3:38 pm
zerocool reacted
On the sizing question, it sounds like at 5' 11 you'll probably be on a large, but just to say I've got a 2020 stage 5 which has similar geometry to the current evos and at 6' I'm on an xl. I just found the seated position too cramped on the large for my liking. That's with a 35mm stem btw. Comparing to Cotic for example, Orange seems to size their bikes slightly differently. Their Xl sits between cotics L and Xl in terms of reach and ett so just something to be aware of.
I love my stage 5 but something I'd probably change is to have a slightly higher bb. Lots of rocks here and you have to be fairly careful when climbing not to catch pedals over rough ground, and that's with fairly short cranks. I think the stage evo is even lower but has less travel obv. Again the bb drop on cotics are a fair bit less I think. Not sure if others find this an issue..
Good luck choosing!
Posted : 29/07/2022 7:34 pm
Love the look of them but too expensive for me. Post some pics if you get one OP
Posted : 29/07/2022 9:07 pm
I just got a 2021 Stage Evo LE a week ago. Only ridden it once but I'm very impressed. I'm 5' 10" and chose a large and it fits perfectly.
I've had several full sus bikes before but this is my first with 29" wheels and progressive geo; I'm sold. I wanted a single pivot again, after loving my SC Superlight back in the early 2000s.
I managed to snag mine at a bargain 26% discount. Wouldn't have paid full price for it. Second ride tomorrow!
Posted : 29/07/2022 9:44 pm
This is where I got mine.
Posted : 29/07/2022 9:52 pm
I had an orange segment for a year, in xl- I'm 6"4.
It was great for the riding you describe.
It had a tiny shock 165*38mm. It was either plushish and bottoming multiple times per ride or hard. I put this down to the very short stroke on the shock.
When I stripped it down, the rear triangle was cracked. Orange replaced the rear end under warranty very promptly and were great to deal with.
I'd have another full suss orange, but only if
- it was brand new
- it had a 50mm+ shock stroke
- it had a long reach. I have a Geometron and hello Dave with 520mm and 530mm reach.
My 5 year old orange clockwork 120 is doing sterling service with a kids ride shotgun on the front
Posted : 30/07/2022 7:29 am
@tall_martin this was still a problem with the later Stage 4, especially with the dinky inline Fox DPS.
As per my comments above, this is now completely resolved, at least if you choose the Float X. It'll be partially the stroke, and partially the much, much better shock.
It now has a much wider window of operation, I can run plenty of sag but also absolutely tw*t it off stuff without the metallic clanging bottom out of the old bikes. It was much easier to get in the sweet spot of tuning too, and the two way climb switch works great for tarmac sprints.
They are much further down the LLS avenue nowadays too (though not geometron-like!).
Posted : 30/07/2022 9:47 am
I've changed that DPS for a cane creek inline air now, it's bloody amazing and so much more supple and grippy.
I didn't really mind the DPS as I liked the "hardtail with a bit of give" feel, but the CC shock and pike have made it a far more capable bike.
Posted : 30/07/2022 10:37 am
@snotrag
Glad that's changed! It was absolutely awesome for the tame/ distance stuff near me. Just not for the more jumpy stuff
Posted : 30/07/2022 11:08 am
I've found the megneg a useful upgrade for tuning the suspension on my stage 5 if you go down the rockshox route.
Posted : 30/07/2022 11:17 am
binman reacted
Love mine, defintley firmer under pedal than the Smuggler I had, and to me, its a perfect balance between speed and compliance.
Just looking to replace the Pike with a new factory 34. To finish it off. 😉
I bought it as '1 bike does all' IMO its pretty good at filling that Niche 👍
[url= https://live.staticflickr.com/65535/51691914642_3986dc7221_c.jp g" target="_blank">https://live.staticflickr.com/65535/51691914642_3986dc7221_c.jp g"/> [/img][/url][url= https://flic.kr/p/2mKQziC ]Untitled[/url] by [url= https://www.flickr.com/photos/17059060@N00/ ]eastham_david[/url], on Flickr
Posted : 31/07/2022 4:49 pm
Thank you for all contributions. Will keep an eye out for a large over the next months.
Posted : 31/07/2022 6:40 pm
Stage Evo LE
Posted : 31/07/2022 7:15 pm
[url= https://live.staticflickr.com/65535/52253057942_7901a372eb_k.jp g" target="_blank">https://live.staticflickr.com/65535/52253057942_7901a372eb_k.jp g"/> [/img][/url][url= https://flic.kr/p/2nBqzE7 ]IMG_20220730_110841333_HDR[/url] by [url= https://www.flickr.com/photos/27050641@N08/ ]Will Jenkins[/url], on Flickr
Posted : 31/07/2022 7:31 pm
nickingsley and binman reacted
I’ve found the megneg a useful upgrade for tuning the suspension on my stage 5 if you go down the rockshox route.
Shock stroke (45mm) on the Stage Evo is too short for a megneg aircan I believe
Posted : 31/07/2022 9:58 pm
Hi @wally, bit of a thread bump! Did you get a Stage Evo in the end? I'm tempted by one to replace my ageing Orange Four and interested I feedback from long term use.
Anybody else? Love my Four but want 'more'! Local singltrack or FOD are my main haunts, withsome trips to Wales planned later I the year.
Posted : 01/06/2023 9:42 pm
If you are missing a bottle mount, I put a frame bag on my segment and that fitted a 2L water bladder.
Posted : 02/06/2023 6:43 am
I've PMed you Fettlin
Posted : 02/06/2023 9:08 am
Love mine, although I am not using it as much as I would like 🙁
Posted : 02/06/2023 10:16 am
I have one, owned it for a year or so. I love mine, had a stage 4 once and didn't get on with that. Geo and shock eye2eye makes it infinitely better imo. I have mine at 140/130 as I have removed 5mm of spacers, had no issues and the ha at 64.5' Is bang on. Taking mine to Madeira next week and I have no doubt it'll be spot on
Posted : 02/06/2023 5:55 pm
Got a Stage 4 as my out of season bike. I absolutely love it. It may be my favourite bike I've ever owned. It can get out of it's depth in steep choss, but it'll still get me down. I can't think of a trail round here (Les Arcs!) that I wouldn't happily take it down. Otherwise, I love the speed and the positivity of it. It just always wants to GO.
Posted : 02/06/2023 6:29 pm
I joined the Stage Evo club, bought as a not coil sprung Enduro weapon and a replacement for my hardtail that I was just no longer enjoying riding....
I also really really loved my short travel Swarf Contour and this is much in the same vain.
Only had 1 ride and well I'm impressed, cable routing was a bastard mind.
Posted : 08/09/2023 3:48 pm
Welcome to the club, you will not regret it 😉
Posted : 08/09/2023 4:25 pm
  1. IMG_7428IMG_7429
    Here’s mine; amazing fun
Posted : 10/09/2023 11:17 am
I joined the Stage Evo club, bought as a not coil sprung Enduro weapon…
it’s funny that you say that - I did see a French guy riding one at this years Megavalanche.
I’ve had mine just over a year and was immediately struck by how capable it was. The geometry is pretty much perfect for me & really encourages a bit of daftness. The Cane Creek Helm forks are superb at 130mm and match the Fox DPX2 at the rear.
Posted : 10/09/2023 11:27 am
Lovely build, looks fantastic in that cherry red.
Second ride this morning and I continue to be impressed, it just wants to go, so much fun to stomp on the pedals and the geometry means I am able to do a big day on the enduro bike yesterday and jump on the Stage Evo today, no adjustments to my riding required. I really struggled to adjust between bikes before.
I had the Cane Creek helm MK2 coils on a previous bike and they are top, but was keen to try the new Rockshox 23 stuff..the shock has hydraulic bottom, HSC,LSC and you can also tune it with different aircans. The Rockshox stuff seems to suit the bike, somewhat firm at low speeds...but once you getting going it feels great.
Only just managed to get a 180mm One up dropper in there on a medium...
Posted : 10/09/2023 8:23 pm
 mboy
How are you all still enjoying your Stage Evo's...?
Anyone weighed a frame only out of interest?
Looking at one as an alternative to both a winter hardtail and an XC bike (though should stipulate the likelihood of it being raced are minimal)... Have a full build kit ready to go on, 2 sets of wheels/tyres (XC and trail), choice of forks etc... Just need to pull the plug on a frame!
Posted : 02/12/2023 9:44 pm
Large with super deluxe was 3.6kg including seatclamp and axle
Posted : 02/12/2023 10:09 pm
 mboy
@tomtomr that's a typo right...? That's heavier than my Geometron G15 frame including hardware and Float X2 shock was!!! In fact, that's heavier than many/most 160mm travel Enduro bike frames available right now...
I know it's ally, but that's got to be a mistake... Back in the days of 26" wheels being relevant, Orange always used to get praised for the 5 frames being lighter than their peers. I wasn't expecting 1800g like an Epic Evo weighs, but even a Geometron G1 only weighs 3.9kg including a coil shock and it comes with an unlimited warranty for use and owners! Not to mention much more travel and a massively overbuilt frame...
Are you sure that figure was correct...?
Posted : 03/12/2023 1:08 am
Posted 1 year ago
The Stage 6 with Ohlins on that link is a bargain. £3700 from £6400
Posted : 03/12/2023 7:53 am
The
Posted : 03/12/2023 8:13 am
It was possibly with the headset as well, so could be a couple of hundred grams lighter than that. I managed not to make a note at the time I weighed it. Built up with carbon bars, gx drivetrain, fox transfer, hunt trailwides and maxxis exo tyres it came out around the 30lb mark (no pedals)
Posted : 03/12/2023 8:50 am
Pretty sure the Orange frames are considered light these days so would be surprised if it's as heavy as stated above?
15% Black Friday discount ends tomorrow I think so pick up your £1300 frame while you can!
Posted : 03/12/2023 12:23 pm
The one that's in the classifieds could be purchased with significant discount over the advertised too... 😉
Posted : 03/12/2023 12:38 pm
 mboy
@snotrag
I PM'ed you on Faceache about your frame earlier... Gimme a shout back as I may be interested.
Posted : 03/12/2023 4:01 pm
Just built one of these, Large frame weighs 13.3kg haven’t ridden it properly yet but feels very nippy equally as fast as my Vitus FS Rapide Carbon XC race bike….😍
A9E011BC-65EA-4422-A1B3-27BCAFB079D6
Posted : 02/05/2024 9:37 pm
fettlin, chestrockwell, tall_martin and 3 people reacted
thought i would post a pic of mine 🙂
its had a few upgrades with only the frame, suspension and dropper post being original the rest has been upgraded
it was a hell of an upgrade from my ev02 HT from 2002
PXL_20240429_174502280
Posted : 02/05/2024 9:47 pm
 mboy
Holy thread resurrection Batman!
How we all getting on with our Stage Evo's then...? Complications meant I couldn't get one at the time, though am now looking again and see the Orange Factory has some half price framesets once again and now with 2 bottle cage mounts and a UDH hanger too...
Posted : 11/06/2025 10:56 pm
Sold mine quite recently. Seemed a good bike overall. If I only had one bike I'd be quite happy with it. Geometry was pleasantly sorted. By my calculations the head tube was a degree slacker than claimed, which is not a complaint. Suspension was fairly dialled as well, surprisingly so given the basic single pivot. Quiet and rattle free. Many bikes rattle like tin cans, so this is a big plus point. Orange were good to deal with. Ordered the bike and the next day someone promptly emailed to arrange a delivery date. The weight was a disappointment. No idea what the frame weighs? But given the lack of bearings and linkages I would have hoped to see a lower whole bike weight. Even with a few lighter parts like carbon bars, 1450g wheels and xc tyres it was still near 31lbs. That put it in a predicament where any kind of xc ride I would take a 6-7lbs lighter Epic without even thinking, and for trail rides a more capable Stumpjumper Evo, which is the same weight.
Mine only had a bottle mount under the downtube, whereas some sold at the same time had one under the top tube as well. I was thinking of drilling a couple of holes and putting rivets in, but never got around to it. The rivet guns at work would have been too big to do it straight anyway.
Orange's new cable routing around the seat tube is somewhat questionable. One of the cables moved slightly and was starting to rub the seat tube quite heavily. Fortunately I noticed early on and put some mastic tape behind it. Worth checking if you own one as there's not much to stop them moving out of position and it would happily eat through the seat tube given enough riding. Tightening them together only makes the rubbing worse.
Posted : 12/06/2025 12:58 am
My Stage Evo frame arrived yesterday - a really good deal on the Orange site was too good to miss! Am swapping out the bits from my 2019 stage 5 - just need to drop the Pikes down to 130mm
Posted : 12/06/2025 7:47 am
Out of interest - anyone running 140mm forks on their Evos? I know Orange recommend 130mm but since I'm changing the travel on my Pikes anyway I could go 130 or 140
Posted : 12/06/2025 7:51 am
Blooming heck, not been checking the last week or so, probably going soft on the idea of swapping my hardtail and having had an expensive month. And now you show me these! Only dilemma is I'd prefer the orange colour but with the Rockshox suspension.
Posted : 12/06/2025 7:58 am
Drop Orange an email - I had a 2024 Evo with the RS Super Delux shock - they may have another one?
Posted : 12/06/2025 8:04 am
sorry - in Fizzy Orange
Reckon they'd probably swap shocks if you asked them?
I run my 2020 Stage 5 with 10mm more than stock and it's absolutely fine. Got a Stage 6 Evo frame landing today to replace the 5.
Posted : 12/06/2025 8:08 am
Oh I'm sure they'd be happy to sell me a full price one with any paint and shock combination I wanted, but I don't want to drop that much cash on it. I'd not be cheeky enough ask them to reconfigure a sale item.
Posted : 12/06/2025 10:06 am
I would!
Posted : 12/06/2025 10:42 am
A great thing about Orange is you can just ring up and talk to them, and they are usually friendly and enthusiastic.
I'd perhaps ask if they wanted a few quid more, and hope they'd say "oh no that's fine".
This frame has the RS shock though: 2025 Stage Evo RS Frame | Orange Bikes
Posted : 12/06/2025 10:57 am
I’ve left my Pikes on my Stage Evo at 130, as supplied, and it amazes me just how capable the bike is and I still enjoy getting on it in all sorts of terrain.
Friend of mine put some 150 forks on his and he batters it over silly stuff. He loves it.
Posted : 12/06/2025 11:11 am
chakaping reacted
On the bike itself - it's still a great option if you want a capable and fun short travel trail bike.
I sold mine a few months ago, but only because I got a Stage 6 Evo frame and that suits me better as an all-rounder.
Posted : 12/06/2025 11:47 am
@tthew I had a marketing email from Orange today about the Stage Evo frameset sale and it said to get in touch if there were any colour and shock combos you wanted. So give them a call and I'm sure they'll accommodate!
I got a frameset in one of the previous sales, it's a great bike, feels spritely yet somehow also  feels like it has more than 120mn travel. I'm taking mine to BPW in July to see how it gets on.
Posted : 12/06/2025 6:30 pm
Didn't get round to calling/ordering yesterday and this morning every option is out of stock. Balls, I reckon a reseller snapped them all up. 🙁
Remember kids, you snooze, you loose.
Posted : 17/06/2025 7:56 am
Give them a bell mate - they've constantly had stock coming and going and can let you know whether to expect more, or even if they have one in your size kicking about still.
Were they not around £1,250 for the frame? Would be a brave reseller buying at that price in the current market.
Posted : 17/06/2025 8:14 am
Oddly, all back in stock by lunch time. 🤷
Rung them as a couple of you suggested, Fizzy orange with the RS shock delivery in 7 to 10 days. 😎
Posted : 17/06/2025 1:21 pm
Ok so maiden voyage today, 25 miles round Mid Wales. And when I say maiden voyage, I really mean it. The shakedown ride was 20 meters up and down the pavement outside my house. Luckily I'd got it all right. Really nice to ride, but a bit bastard hot!
Posted : 12/07/2025 9:37 pm
That's a beauty, great build too.
Posted : 12/07/2025 10:23 pm
Having had a Segment, Stage 5 and Stage Evo my favourite would be the Evo , rode like a bike with more travel and great pedalling efficiency.
Pains me to say after breaking 6 Oranges in total I have moved away from the brand totally, I do miss the simplicity of the single pivot and alloy frame , just time to say goodbye
Posted : 13/07/2025 2:44 pm
Oh, mememe, I get to join the owners clique.
I'm loving it - it's a 'pert' ride, responsive enough, absorbing enough, rewards speed and good lines not just battering through. Love it in fact.
Despite Orange specifying cheese for a rear hub which literally put the pawls through the hub shell...
https://flic.kr/p/2qsES8T
Posted : 13/07/2025 5:11 pm
I've had at least one Orange mountain bike in my garage since I got an Orange Evo O2 hardtail in 1999. Although this new bike bought in May isn't an Evo, (It's a new, old stock Stage 6 that I got from the Start Fitness outlet shop after a PSA on here), it's still the best riding and most capable mountain bike I've ever owned. On a recent trip down t'Lakes this bike had me riding descents that I haven't looked at in years for fear of coming a cropper. It took on everything that was put in front of it and positively demanded to be popped over every lip that could be found.
I think I've only ridden my Spesh Levo e-bike about twice this summer because the Stage 6 is so much more fun. Less than four weeks now till I take it over to the Alps for a week with The White Room MTB. I'm quite excited.
p.s. Sorry for barging in on your Evo lovefest. 😘
Posted : 14/07/2025 7:12 am
Hi all, could anyone help with the dropper insertion depth on a large Stage Evo? I'm hoping to get a 210mm Oneup pretty much slammed. Thanks.
Posted : 01/08/2025 4:40 pm
On that vein what is the seat tube height for a large or XL. Orange list it a funny way in inches. I have short legs and long upper body. So want a long reach but need to be able get the saddle low enough
Posted : 20/08/2025 1:23 pm
I will go measure my Large tonight for you.
Posted : 20/08/2025 3:59 pm
The XL is 19"(482.6mm) from the centre of the bb to the top of the seat tube. They dropped 2" off it a few years back. Pretty standard these days I think?
Posted : 20/08/2025 4:10 pm
Just multiply it up by 25.4...
Medium is 17", large 18", xl 19".
I'm pretty sure you can get *almost* full insertion down the seat tube.
There are no bottle bosses and the dropper cable is coming up from the BB not through a grommet.
Posted : 20/08/2025 5:17 pm
Sorry my question wasn't about converting inches to mm. My understanding was that most brands measured the seatube height vertically from the bb not the actual length. Maybe I have it wrong they just seem a little high relative to other bikes I've owned
Posted : 20/08/2025 9:02 pm
I went ahead and ordered the frame. Haven't built it up yet but the seat tube insertion is indeed long. I roughly measured it and it's at least 300mm, maybe more like 320mm, size large.
Yes the seat tube length is long compared to other brands. My Bird, and the Fuji this is replacing, are both 420mm for a similar reach length, this is 458mm.
Posted : 21/08/2025 5:16 am
Nice one, it's an awesome bike.
Enjoy the cabling 😉
Posted : 21/08/2025 7:12 am
Thanks, any particular tips or pitfalls on the hose routing? I'm guessing it's not tube in tube?
Posted : 21/08/2025 7:49 am
 StuE
Just rubber grommets on the holes, which can be a v tight fit.
Most of the routing is awkward but do-able, the dropper post round the BB is the killer. Start practicing your calming breathing exercises now.
Posted : 21/08/2025 8:11 am
 StuE
Posted : 21/08/2025 8:23 am
New from Orange my frame came with plastic tubes in situ to help.  It’s all a bit fiddly but doable without any special tools if you have the patience and dexterity.  I slid some foam tube over all my cables in the main frame to avoid rattles too.  The grommets are a bugger to fit but warmth and some silicone lube helped
Posted : 21/08/2025 8:53 am
