Orange Five Mk2 tri...
[Closed] Orange Five Mk2 triple ring setup
14 Users
I have recently bought a new mk 2 orange five and want to know if I can fit a triple ring crankset. Orange website says the bike is designed for double rings only, but is anyone using triple rings. Also, if it will accommodate a triple ring then what size big ring is best suited for 650b wheels- 42t or 40t My last bike was a Marin running 3x9 on 26 inch wheels with 44t. Cheers. Ian.
Posted : 21/02/2016 2:32 pm
Think newest 5 is single ring only see latest build thread from Mosey MTB on here.
Posted : 21/02/2016 2:46 pm
 S_J
You can run the current Five with 2x, I've ridden one with a 2x10
Set up so I know it works! See no reason why a triple wouldn't work
Posted : 21/02/2016 2:51 pm
I built my mk2 frame with an existing standard slx triple chainset I had, shifting was fine. I've since converted to a double / bash setup, no real need for the outer ring on that bike 🙂
Posted : 21/02/2016 3:16 pm
Thanks for your advice. Much appreciated. So you know, I will fit a triple now I know it fits. I need the bigger ring simply to go faster DH. The double and bash big ring is only 32t and just doesn't provide the sheer speed that a 44 will. Thanks again.
What tooth big ring is best for 650b wheels, 40 or 42.
Cheers.
Posted : 21/02/2016 8:04 pm
My MK2 has no front mech compatibility so is single ring only.
Posted : 21/02/2016 8:06 pm
According to the Orange website you can use an e-type front mech on a Mk II.
Posted : 21/02/2016 8:13 pm
Depends how new the MK2 is. Very latest ones are single ring front only. They deleted the cable guides, stops and derailler mount.
If you have these mounts then is an E2 mech and they all seem to be 2x10 or 2x11
Posted : 21/02/2016 8:21 pm
Check my thread.
The new, new one doesn't have e-type mounts
I spoke to Orange about this, they said they were updating the webpage.
[URL= http://i1143.photobucket.com/albums/n635/mosey82/F8AF0DCD-DF78-4C4F-9104-803F13569CF1_zps1hfxhjur.jp g" target="_blank">http://i1143.photobucket.com/albums/n635/mosey82/F8AF0DCD-DF78-4C4F-9104-803F13569CF1_zps1hfxhjur.jp g"/> [/IMG][/URL]
Posted : 21/02/2016 8:41 pm
Thanks for all the advice and the picture. My frame is the 2015 mk2 frame and does have the mounts on the frame to fix the mech to it - now all I've got to find out is if the mech fitted with the bike can be adjusted to work a triple ring. It is supposed to be an SLX according to the spec sheet so if it is the bog standard SLX then it should be do-able.
It will be a week or two before I get to it but I will update the forum to say how I get on with it.
Posted : 22/02/2016 9:29 am
etype can mount around the bb.
Posted : 22/02/2016 10:24 am
Wow, 1 x 11 seems a bit of a limiting choice for a bike like the Orange 5. Glad I found this out. I was just about to get one for my wife, there's no way she'd be happy riding 1 x 11.
Posted : 22/02/2016 11:04 am
Mosey does the frame in your picture have cable guides for a front mech?
Posted : 22/02/2016 11:34 am
Burchy looking at the pics on Moseys MTBs thread and I think the top tube guides would be on driveside, nothing on Moseys
Posted : 22/02/2016 12:23 pm
Tricky, just had a look at the other thread, you're right, no guides. Wish i'd have waited a few extra months. The e-Type mount collects mud on mine!
Posted : 22/02/2016 1:27 pm
Pretty sure you could still source one with the mount, at least for the time being.
Posted : 22/02/2016 1:29 pm
Yep, no mounts. Orange sorted me out with a new drivetrain as the site sells the frame as old.
Posted : 22/02/2016 7:23 pm
I've tried a couple of shops, but no joy in small
Posted : 23/02/2016 8:56 pm
You barely lose any easy gearing with 1x11, using a triple or a double isn't really gonna give you anything, apart from a lot of the same gear ratios in redundancy.
The Five is really an all day trail bike, which is perfect as 1x11. A triple is great for a touring bike, when you need massive gears for spinning on the road, and need easy gears for big climbs.
42t front ring required for descents? You are Aaron Gwin and I claim my £5.
Posted : 23/02/2016 11:02 pm
Orange had smells in with mounts. They offered me one after I told them about the no mech issue on mine.
Give them a ring
Posted : 23/02/2016 11:04 pm
I hope MoseyMTB meant smalls rather than smells as I was wondering what kind of smell Orange were offering. A nice refreshing mint to go with his frame colour or a sharp citrus tang to go with their more traditional colour? Or maybe it could mean the smell of a welders smalls? 😉
Posted : 24/02/2016 2:02 am
In some ways a triple may be better than a double on a 5 as some of the larger middle/single ring options could foul the pivots (unless the redesign moved them a lot)
My last double was 24/39 it gets Damm close though I struggle to remember when I was last spun out up that range where gravity wasn't taking over
bluebird - Member
It really really isn't - a 10-42 with a 32t up front drops 2 1/2 gears from a 24/38 double on 11-36. You can size up to a 34 or down to a 30t to cover one of those ends.
Posted : 24/02/2016 2:45 am
They ride transition 29ers I think, not fives
Ok. Here is the outcome of my original enquiry.
My frame (2015 mk2 version) had the mounts for an E2 type front mech. From what is in everyone's posts the 2016 frame is missing these mounts so it may be impossible to put a front mech on a 2016 mk2 frame.
I have fitted a new 3x10 speed E2 front mech and a 42 tooth big ring and a new long cage rear mech. The bike now has a triple front ring set up and it all works just fine.
I am really pleased at how well it all fitted together and how well it works.
Thanks for the advice.
Posted : 12/03/2016 11:24 pm
