Hi all, ia am after some help, I have just bought an orange five 07, wanted one for ages and finally found one.... I have been trying to find the specifications and can't find them anywhere - any ideas
The sizes can be found on the FAQ's at Orange site:
http://www.orangebikes.co.uk/support/faqs/#table
This gives most tube sizes for posts, bb etc if that's what you are after.
Hope that helps.
Martin
Review here might be of use
I've got the full 2005 brochure pdf, not sure if there were any changes between then and 2006/7. but it has all the geometry info for the five. mine can take 120-150mm forks but i/m not sure when it changed to 160mm max. email in profile if you want it.
I have one in a size 16" what you after finding out. Run mine with 140mm forks and love it.
07 was the first kinked top tube and probably one of the biggest changes I think.
Thanks not got bike yet so after info on suspension setup ie what mm, rear wheel figment std 10mm and std rear rotor size, thanks for all help and info so far
prolly differetn to mine then. OP put 06 in title and 07 in text though.
Doh ! It's an 06 !
