Hi everyone
Need some help getting my brake cable through my five swingarm anyone got any tips ?
Had 3 O5s over the years,
Straight Coat hanger type rod through the shock end of swing arm, fiddle a bit, gaffer tape string to exposed end, pull through, attach cable, pull back.
Don’t bother with specific orange rubber Grommets, an inch of camel back hose is far more effective
Oops, wrong way round.
Rod through drop out end ((smallest hole) grab cable through swing arm ( biggest hole) 😁
2 stick on cable guides on top of swingarm - problem solved
Vacuum cleaner to suck cotton thread through. Block off all the other holes you can, should be doable on a swing arm. Then use the cotton to draw string through, then tape string to the outer and pull it through
long bit of cotton/wool & a vacuum cleaner
Yup, vacuum cleaner and cotton thread. Tie it to the nipple end of an old inner cable, pull through, then feed the outer over it.
Thanks everyone shouldn't be too hard getting the vacuum cleaner off the Mrs !!
We need a pic of her face when she sees you vacuuming your bike.
Cock stuck in vacuum cleaner alert😂
Thanks everyone shouldn’t be too hard getting the vacuum cleaner off the Mrs !!
do you need step by step instructions on how to use it? do you even know where the iron is kept?
