Options for Sram Ca...
[Closed] Options for Sram Cassette replacement
7 Users
As above. Ive bent a couple of teeth on my rear cassette's largest ring. I was hoping to just swap out the largeest ring with one of those from On Up components. But having taken off the cassette ive discovered its all just one stuck together block. If i swap the whole thing id want something a bit bigger than the max 42T size you get on sram 1x11.
So who does alternatives that work with the Sram XD hub? Whats the most cost effective route here?
Thanks
Posted : 22/09/2017 8:57 am
No one as far as I know-cheapest like for like replacement is their GX level one at around £80 .
Posted : 22/09/2017 9:06 am
Nobody does larger than 42 on SRAM except Eagle (which is a full groupset change at £260).
Best option for a lower gear would be to reduce your chainring size.
Posted : 22/09/2017 9:44 am
One-up does a 44T aftermarket bottom cog for XO1/XX1 cassettes (CRC have them). That's as large as you get. They just prize off with a large flat bladed screwdriver - although be aware they are clocked for position - there's a single larger hole on the cog and a single fat pin on the rest of the cassette to align with.
Wolftooth also do a like for like 42T cog.
Posted : 22/09/2017 9:50 am
Good find Jon. Although, even One-Up say
COMPATIBILITY: SRAM XX1 (XG-1199) and X01 (XG-1195). Not compatible with X1 (XG-1180) or GX (XG-1175, XG-1150) fully pinned cassettes, the largest sprocket on these cassettes are not pressed on but riveted and therefore can not be removed.
Posted : 22/09/2017 10:00 am
So i think i have GX on mine, so swapping out for the One Up ring isnt going to work due to the riveting?
Posted : 22/09/2017 10:26 am
That's correct, you need an XX1/X01 cassette to be able to use one of the aftermarket 42/44T replacement rings.
Why not replace with the same?
Posted : 22/09/2017 10:38 am
As mentioned in first post, it would be nice to have a slightly bigger gear that 42T. Especially if im having to fork out over £80 for a new cassette.
Posted : 22/09/2017 11:14 am
E13 cassette works on Sram XD doesn't it? Not cheap though.
Posted : 22/09/2017 11:24 am
The [url= http://www.chainreactioncycles.com/e-thirteen-trs-plus/rp-prod145555 ]E Thirteen cassette[/url] with 9-44 range fits an XD Driver.
£205 isn't cheap by any means, but you can buy the two halves seperately when one or the other wears out. Whether that's cost effective down the line, I'm not sure
Edit: beaten to it^^^
Posted : 22/09/2017 11:29 am
