Open and closed hyd...
[Closed] Open and closed hydraulics
9 Users
Hi there STW,
I spotted [url= http://www.ebay.co.uk/itm/Hope-Mono-Mini-and-Hope-Mono-04-Hydraulic-Disc-Brake-set-/291109209945?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item43c7760759 ]these[/url] on eBay and the seller assures me it works a treat, but I always thought you couldn't mix 'n match open and closed brake components?
Does this really work?!
Cheers,
Adam
Posted : 25/03/2014 12:36 pm
As far as I know it's the lever that determines an open or closed system. So no reason why I different caliper wouldn't work. Closed just means there is no 'self feeding' reservoir to compensate for pad wear and fluids expansion.
Posted : 25/03/2014 12:41 pm
The brakes are ancient, an extra couple of quid will get you something a lot better.
Posted : 25/03/2014 12:42 pm
+ this.
£55. buy some new deore brakes - miles better.
Posted : 25/03/2014 12:47 pm
I'd be worried that the piston size ratio between the levers and calipers wasn't right too.
[advert]
I could sell you a newer pair of Magura Marta's with 160mm disks for the starting price of the auction.
[/advert]
Crikey that was quick..!
I'm looking to replace a leaky M965 caliper- how do new deores compare? I'd pretty much convinced myself it isn't worth finding a new caliper to run on the old levers and fancied something different. Are the older Hopes worth looking at all or shall I really just sack it in and get new deores? Was looking at Mono Mini rear/M4 front combo..
Cheers,
Adam
Posted : 25/03/2014 12:57 pm
 cp
Those Hopes are a backward step from your Shimanos. I'd look at just getting some new Deores.
76.99 gets you these
http://www.merlincycles.com/shimano-deore-m615-disc-brakes-front-rear-set-62194.html
Posted : 25/03/2014 1:01 pm
Those hopes must be over 12 years old. I wouldn't get anything older than the Hope Tech lever. X2 M4 style. I think some went in the classifieds for £80-90 the other day.
Posted : 25/03/2014 1:11 pm
wwaswas - Member
Is there any brake company who uses different levers/ratios for different calipers?
Posted : 25/03/2014 1:13 pm
Can't look at the link from here but closed hope brakes had piston return springs so the wouldn't self adjust even with an open lever.
Posted : 25/03/2014 1:16 pm
If you want Hopes, I'll sell you a M4 front and mini rear with proper levers for £40
Email in profile if interested.
Posted : 25/03/2014 1:19 pm
