Ooops, Scott Spark ...
[Closed] Ooops, Scott Spark pivots…
15 Users
So, my bikes in the shop having a it’s bearings replaced…. And all the pivot bolts. Apparently the bearings had seized and have been rotating on the bolts almost shearing them and making extraction of everything a bit touch and go.
So firstly, please don’t leave your suspension for 3 years without inspection (guilty), and secondly I just wondered if others with Scott’s/Sparks have experienced this?
The shops says the bearings are pretty low quality, which you might expect being a hidden OEM part but not on what was a £3.5k bike in 2018, which is a tad annoying especially as they are a lower grade than the replacement kit. Odd.
Posted : 17/08/2021 7:51 am
3 years... that's quite a while without doing them mate !
Bearings are always cheaper in the OEM of bikes.
Posted : 17/08/2021 7:54 am
Each time I do an air can service (few times a year), I'll pop the bike in the stand with the rear wheel off and cycle the linkage. Gives a pretty good idea if any of the bearings are getting lumpy.
Posted : 17/08/2021 7:55 am
You think getting sub standard frame bearings is bad, back in 2015 my £4.8K Foxy XR Carbon (and indeed the £6K range topper) came with loose ball and cage bearing headsets! And the less said about the constantly loosening pivot hardware the better!
Posted : 17/08/2021 8:13 am
The bearings in the Scott kit are exactly the same as the original build bearings.
Squeeks in the spark/genius mean the main pivot bearings have gone. I havent experienced any having a quiet death. Often sounds like bottom bracket bearings.
I also havent seen any linkage bearings go before main pivots.
To be fair, the flex stays do make "shock out" bearing assessment a little less easy than non flex pivot bikes.
Posted : 17/08/2021 8:25 am
The shop thinks not but it doesn’t matter as mine are being replaced with ceramic bearings by choice (I want a couple of more racing years from my frame).
That’s exactly how I got to this point, the bike was creaking away. Whilst in the shop and in pieces pretty much everything’s - all still oem - being replaced, headset bearings, cables, BB for a c-bear ceramic and of course the suspension bearings. Fork and shock were serviced six months ago. Time has flown tbh, I can’t believe I’d left it for so long. Still, the bike should feel good when it’s back.
Posted : 17/08/2021 8:33 am
I just can’t ride a creaky / clicky bike - if it starts doing that on a ride I’ll have a look over it before the next ride and fix whatever the problem is. To saw through pivot hardware it must have been creaking for ages 😳
Posted : 17/08/2021 8:57 am
Tbh it wasn’t that loud, and maybe… 4 months? I may have inadvertently hidden it by shoving a load of Park grease under the bearing caps before Christmas.
As you might tell, I’m not good with my hands / mechanically so as much as I’d love to be able to service my own suspension bearings and pivots, I darent. But notwistanding that it should have been in a shop sooner.
Posted : 17/08/2021 9:06 am
Lol - 4 months 🙈
I just changed all the bearings in my Bird Aether - at about 18 months old. They’d probably have soldiered on a bit longer and weren’t creaking but I rode them through all sorts of slop and bog over the winter so a few were beginning to feel a bit secondhand.
Honestly it wasn’t that hard - cheap Chinese press kit from eBay and mostly a mallet and drift. Just the rear blind bearings that were a bit trickier to get out with a little slide hammer set (also from eBay and pretty cheap). Was really satisfying to do it myself - I think the only things I can’t / won’t do now are a full rear shock service (happy to do just aircan) or touch the charger damper in my forks.
Posted : 17/08/2021 9:09 am
Watch out for the rocker / seat tube pivot bolt breaking too, the heads are super thin and are known to fail, apparently its a consumable part that should be replaced after X hours along with the bearings - bit shit if you ask me.
Posted : 17/08/2021 9:25 am
Ceramic bearings are not an obvious choice for frame pivot bearings, why are you using them?
Posted : 17/08/2021 10:15 am
I've been looking for a cheap press for frame and wheel bearings. I was also looking at a blind bearing tool so I'm not having to tap out the wheel bearings with a large screwdriver.
Any links would be appreciated.
Posted : 17/08/2021 10:36 am
Nice one thanks.
Posted : 17/08/2021 11:43 am
apparently its a consumable part that should be replaced after X hours along with the bearings – bit shit if you ask me.
Never happened to me?
Sorry I rushed and confused post. It’ll have the suspension bearings that come with the kit, the BB has ceramic bearings.
Posted : 17/08/2021 2:25 pm
 igm
The bearings in my Orange Alpine lasted 10 years with a complete absence of love.
But they are a relatively large bearing.
Posted : 17/08/2021 3:12 pm
igm
They also have a relatively large amount of rotation which helps keep them alive, linkages tend to have much less rotation which basically stresses small areas of the total bearing more.
Having said that, I reckon most Oranges if you pull them apart, you'll find 2 knackered bearings- it's just that with simple designs and lots of leverage it tends to be less obvious. Every time I've worked on one it's needed bearings and the owner's been surprised.
Posted : 17/08/2021 4:14 pm
I just changed all the bearings in my Bird Aether – at about 18 months old. They’d probably have soldiered on a bit longer and weren’t creaking but I rode them through all sorts of slop and bog over the winter so a few were beginning to feel a bit secondhand.
Honestly it wasn’t that hard – cheap Chinese press kit from eBay and mostly a mallet and drift. Just the rear blind bearings that were a bit trickier to get out with a little slide hammer set (also from eBay and pretty cheap). Was really satisfying to do it myself – I think the only things I can’t / won’t do now are a full rear shock service (happy to do just aircan) or touch the charger damper in my forks.
How were the chainstay bearings? I nearly lost my mind changing them on my Aeris
Posted : 17/08/2021 5:04 pm
Mine came out reasonably easy but they were only 18 months old.
Posted : 17/08/2021 7:18 pm
I didn't own mine long enough, but had to pull the pivots apart a few weeks into owning it due to a horrid creaking/cracking noise.
Turns out that whoever assembled it absolutely covered it in loctite. it was all over the inside of the pivots and causing all sorts of binding.
Posted : 17/08/2021 8:14 pm
Any full suss bike I’ve had, twice a year strip and check/replace bearings, re-grease etc, usually Oct and March time, not a bit difficult job, but keeps bike maintained like we all should do
Posted : 18/08/2021 11:37 am
 Yak
I check and replace them all about once a year, or earlier if needed. Sometimes it's just the lower linkage, but often the full set.
Posted : 18/08/2021 11:54 am
