OneUp Pump C02 Infl...
[Closed] OneUp Pump C02 Inflator
2 Users
Has anyone had much success with their Oneup CO2 inflator?
I had to use mine the other night, apparently you should screw it onto the canister (at which point it started to lose air while attaching) and then when it's tightly on it should be closed - although mine kept losing a small amount of air.
Unscrewing the canister slightly releases the air, which works as expected - but when I tried to close it again it just kept leaking - although only slowly.
Is this normal, or have I got a duff one?
Posted : 01/08/2019 4:02 pm
Probably a slightly duff canister, I'd say the tolerances on those are more likely to be off than the OneUp
Posted : 01/08/2019 4:51 pm
