Oneup edc pump and ...
[Closed] Oneup edc pump and fidlock bottle
4 Users
Does anyone use both of the above together. Fancy the edc pump and tool so I can ride local stuff without a backpack but wasn't use if the pump would get in the way of the bottle when twisting to unlock it?
Posted : 18/09/2019 9:38 am
I tried and the bottle hit the pump. The pump bracket can be positioned further out to avoid this, but then it's not supported by the down tube. I got some of these and attach the pump under the top tube, which works great: https://www.amazon.co.uk/gp/product/B005I4GVQA/
Posted : 18/09/2019 10:43 am
That's a shame but to be honest looking at the pics online of the pump mounted I expected it to hit!
How bad does it hit? Enough you could space the bottle mount up slightly for clearance?
Posted : 18/09/2019 9:40 pm
i use both together, just need a washer between the pump mount and fidlock mount. Potentially you might need longer bolts but not to hard to find.
Posted : 19/09/2019 5:44 am
Thanks. Just or normal washer or a thicker one? I've not idea how bad it hits. I've order the pump and tool
Thanks
Posted : 20/09/2019 7:24 am
@sam1988 did you get anywhere with this? I have the fidlock system at the minute and considering the EDC pump as opposed to the mixed reviews of the EDC stem
Posted : 12/04/2020 7:44 pm
On my 2019 whyte t130s I found I needed to space it out alot so that it didn't hit, I didn't like it like this so I decided to just put the edc bump in my hip pack with a tube. I have two bikes so what ever one I have I've always got the tool and pump in my pack. It's the smaller version of the pump and fits inside a dakine hot laps stealth just fine. I'm very impressed with the tool and pump itself just done actually mount it on the bike, only downside would be if I got a puncture I wouldn't be able to quickly get a bacon strip out in a few seconds and plug the hole like on the one up promotion video 😂
That said Ive seen someone with a carbon s150 and that fits fine without hitting, I think the wider the downtube the better!
Posted : 12/04/2020 7:50 pm
