On one whippet help
[Closed] On one whippet help
6 Users
Ordered a whippet frame, what droupouts are prodivided with the frame?
Posted : 24/12/2011 8:40 pm
Vertical.
Posted : 24/12/2011 8:44 pm
Would imagine horizontal but they pretty good if you need to swap them
Posted : 24/12/2011 8:46 pm
KINGTUT- Is that an educated guess?
Posted : 24/12/2011 8:49 pm
At one point they supplied the ones you chose but if you dont specify you'd get vertical i'd imagine...... i bought both for mine! 😉
Posted : 24/12/2011 9:02 pm
So i'll assume that vertical ones are supplied. cheers
Posted : 24/12/2011 9:20 pm
When you ordered the frames did you read any of the spec info?
"Swapouts - run singlespeed or gears (geared version is supplied, slot version available separately)"
Posted : 24/12/2011 9:24 pm
A bought one a month or so ago and it came with vertical dropouts. I needed horizontal and it was easy to swap 'em.
Posted : 24/12/2011 9:26 pm
Might have missed that point
Posted : 24/12/2011 9:37 pm
