On One whippet chai...
[Closed] On One whippet chain problem
5 Users
Chain keeps getting wedged around the chainstay, theres not much room between inner ring and the chainstay.
Anyone else this problem.
Posted : 27/01/2013 11:59 am
Solve the problem by converting to singlespeed 8)
Posted : 27/01/2013 12:06 pm
Check your derailleur adjustment. Had a problem with this on the same bike myself. Assuming you're using X9 transmission?
Posted : 27/01/2013 12:14 pm
Mr Mills has a sad life.....
X5 cranks X7 front der
Posted : 27/01/2013 8:04 pm
If your running 3 x 9 it's nothing to do with your set up. My missus had this problem and had it adjusted to perfection by 2 good mechanics. Regardless every time she dropped into the granny ring it would get jammed around the bb and the chain stay.
Spoke to On One and asked why they said it would work with 3 x 9 as it as ruining the frame by taking chunks out of it. They said the info is out of date on the website and apologised. Moved to 2 x 10 and its never happened again.
Hope this helps a bit,
Other than that, lovely little frame.....
All the best,
Lee.
Posted : 27/01/2013 9:44 pm
Using 2x10
Wondering if chain could be a bit long?
Posted : 28/01/2013 8:09 am
 DT78
Have a read of Sheldon browns site for chainsuck. Most will tell you it is down to dirty components but I'm positive chain line can effect it. After months of trying to sort on my hardtail I tried steel deore rings, 26 /36, no more chainsuck!
Posted : 28/01/2013 8:45 am
Posted : 28/01/2013 1:25 pm
