Hi,
I'd like a Whippet frame, but I have an older XTR 960 triple crankset with 64bcd inner ring. I've heard that BB92 shell has clearance issues... Did You tried the same or similar build?
Thanks a lot!
I have a whippet & just put a m770 crank in it with the Fsa BB off on-one
Yes it is very close but worse case scenario you would just chamfer the edge of the chain ring to suit a little
No problems but I didn't need to.
Also did the 1mm spacer under the direct mount xt mech as explaind in the on-one website ,Works a treat, didn't use the last cable stop for the f mech as my xt has its own & it would just hinder the cable routing.
