Little bit of help please - putting some new race face turbine cinch cranks on my on one ti 456 ( Lynskey ) 2010 I think and want to know which hope bottom bracket to use - is it a 73 mm shell with a 30 mm spindle on the cranks? Any one suggest which BB I need please ?
Thanks
That's an awkward question, most bb's for threaded frames are designed around a 24mm shaft. The new screw-in bb that hope has designed specifically for their crank may do the job but you need to check that the bearings will be the right spacing beforehand. You would also need the special tool for installation.
Personally, I would swap the cranks for some with a standard 24mm axle.
