Evening all,
Off the top of anyone's head do I need to get replacements drop outs for both sides if changing from geared to SS or is it just the drive side that would need replacing? Don't have the frame to hand to check and OO's website neither confirms or denies.
Thanks 🙂
Both - the geared ones are both a vertical slot for the rear axle to locate, whereas the ss ones are both a long rear facing slot to allow the axle to slide for chain tension.
Yep, both. If you need the ones for a Mk2, I have spares somewhere you can have in return to a donation to Cancer Research or similar.
@bent udder; That would be awesome if you have, happy to ping a donation to Cancer Research for what they would cost from O.O.
Will send you a PM 🙂
